Thread: *Urgent* need help identifying chain, 7/8th or 15/16?
Results 1 to 19 of 19
  1. #1 *Urgent* need help identifying chain, 7/8th or 15/16?
    SE Level Member 92bird's Avatar
    Colorado
    I'm assembling my built transmission, with a new 300m input shaft and a used (supposedly less than 500 miles) 2.93 single chain set. Upon assembly, the chain appears stretched.. I can press on it and it touches the bottom of the case.
    It looks a little different than some of the 7/8 chain sets I've seen pictures of, so I am wondering if this is a 15/16" chain? The measurement shows it to be more the size of 15/16th, at 0.9325" in a caliper.
    This is for my turbo GTP.. Does anyone know where I can get a replacement chain and which one this is? Was hoping to install this trans next weekend.
    See pics: sc92bird's Library | Photobucket
    Thanks,
    Jeramie
    2000 GTP: ZZP Z7 turbo kit,Precision 5858cea Billet turbo,F&R p-logs,L26 upper/lower,HV3 insert,60lb inj,L67 Throttle/MAF,1.95 Yella Terra rockers,PAC 105 springs/titanium retainers,3" exhaust,full suspension,Self-built 4t65e with zzp 300m input shaft, TEP 7/8" 2.93 chain set, blue plate clutches,PI 2800 stall billet cover converter
  2. #2 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Apr 2011
    Vassar, Mi
    if you can ball it up or fold the chain around backwards it is a "15/16th" style, if it is straight and will not fold over it is a "7/8th"
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  3. #3 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    May 2008
    Schuyler, NE
    That is a 15/16's.
  4. #4 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Like everyone said...15/16...and you're really gonna want to run the 7/8" instead.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    I have pics of a caliper on a 15/16" if you need it. It's also the only chain I've seen snapped. Adding further..the gearset is not the same between the 15/16 and the 7/8 chaings. Pitch (I think it's called) is slightly off. Clearly ...as you know the chain touching is too stretched to use. ATSG book says you should have 1/8" or more to the case.
  6. #6 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    May 2008
    Schuyler, NE
    You're lucky...15/16" chains usually don't stretch. They just break.
  7. #7 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Ohio
    This
  8. #8 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Colorado
    Thanks for the confirmation guys, I just ordered a 7/8th 2.93 chain set from Dave @ TEP. I was tempted to wait for zzp's new chain, but I just want to get the car back together at this point. Its just a rockered GTP with an intercooled 58mm turbo, so not insane like some of the other turbo builds around here. Might run mid 12's.
  9. #9 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    GT Level Member penright's Avatar
    Mar 2013
    United States
    I would have thought a thicker chain would wear better and be stronger. So are they made different? Is that why the 15/16 can be balled up?
    07 Grand Prix GXP (My Daily Driver and future toy) (120,000+)
    97 Grand Prix GT (Project Car) (178,000+)
    02 Mustang Convertible (Wife's Toy) (75,000+)
    17 Honda Civic (Wife's Daily Driver)
  10. #10 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Colorado
    I think the roller vs rocker design is where the weakness is. This chain was pretty stretched with only 500 miles, but it also had several track passes on it from a VSx cammed GTP on a 100 shot of nitrous on slicks.. That car dynoed 440whp, so the 15/16th chain is not adequate for that power level. I hope to be around 400whp with my setup on E85 and more boost, so I figured if the 7/8th is a little stronger it would be better for me.
    If anyone is interested in my 15/16 single chain setup (2.93) ratio with a brand new chain, send me a PM. I bought a brand new chain before deciding to go 7/8th. The gears are tapped and the reluctor wheel is screwed on and red lock-tited down so it will never fly off. This setup would work for lesser hp supercharged guys, and I'll let it go pretty cheap. PM for details.
  11. #11 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Some of us can kill that "never coming off" w/o trying hard.
  12. #12 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    GT Level Member ls1camino's Avatar
    Laurel, MD
    Love my 1" chain
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  13. #13 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Mar 2013
    United States
    Quote Originally Posted by ls1camino View Post
    Love my 1" chain
    Do they make a 1". Somewhere I read they didn't make them or they quit. So, just like my question on the 15/16 - 7/8, I would have thought the more width the stronger the chain. I guess unless they cut back to lighten to cut down on rotating mass. If I read some post here right, I guess how the 15/16 is constructed actually make them weak. So if there is a 1" chain, what is it's pros and cons compared to the 15/16,7/8?
  14. #14 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Laurel, MD
    Quote Originally Posted by penright View Post
    1" is the best you can get. It was made by GM for their racing division. They pop up for sale every once in awhile for the average cost of $2000. I've never heard of one failing.
    5/16" chains snap.
    7/8" chains stretch after awhile.
    The lack of a good chain is the main reason you don't see more turbo 3800s. Some are content replacing their 7/8" chain every 10k miles and others are content on replacing their stock trans with another stock trans when they finally catch traction and pop something.
  15. #15 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Laurel, MD
    For example:
    ClubGP Message Forum troubleshooting
    Here's a pic of my 1" chain:
  16. #16 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    In talking to Dave at TEP, he referred to the 15/16 as a mismeasured older 7/8. Anthony and some others can probably comment on it more, I believe the way the chains are put together is different, which keeps them from folding on themselves etc and makes them stronger.
    Also..on the 1" there are two different versions. There's the 800hp set and the 1200hp set. The Ecotec guys started snapping the first version.
  17. #17 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Colorado
    Hey, if you can't beat someone at the track, you can at least fling a reluctor wheel at them..
    But seriously, what is the do all end all solution to not tossing your reluctor wheel at your opponent like a chinese star?
  18. #18 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    Colorado
    I also heard ZZP's new 1" chain that is due for release in August is still a HyVo rocker chain. Basically a 7/8" chain with 2 extra links, the material is no different.This leads me to believe that, combined with only being offered in a 3.29 ratio may not be as durable as it sounds. Surely better than the 7/8" but by how much? I'll let someone else be the guinnie pig, and maybe after I stretch my 7/8" give the ZZP one a shot if its doing well in other people's cars.
  19. #19 Re: *Urgent* need help identifying chain, 7/8th or 15/16?
    The answer is ...don't drive like me.
    In under 2000 miles I was able to stretch the 7/8"
  1. Need help identifying vacuum line...
    By NerdPower in forum General Grand Prix Discussion
    Last Post: 04-23-2012, 10:17 AM
  2. Need help identifying part
    By hotshot26 in forum General Tech Discussion
    Last Post: 02-14-2012, 05:32 AM
  3. Need Help Identifying These Rims
    By nawarkk in forum Tires & Wheels
    Last Post: 11-29-2010, 04:05 PM
  4. Help identifying a part
    By RSTraveler in forum Introductions/Noob Questions
    Last Post: 10-18-2010, 02:43 PM
  5. Identifying a 4T65E-HD?
    By 2M8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2008, 07:56 AM
