Thread: Transmision won't go into gear
Results 1 to 7 of 7
  1. #1 Transmision won't go into gear
    SE Level Member gtpdriver's Avatar
    south dakota
    Ok, so i bought a new truck and have been driving that for the past 6 months but now that it is summer i decided to get my 2000 gtp going. The battery was bad when i parked it and just grabbed a new one and put it in. When I started it up and tried putting it in gear i could hear that click under the dash when you pull the lever on the shifter but shifter won't move. It also feels like the shift lever doesnt go in as far as it used to? help would be appreciated on where to start on this one.
    Msp cold air/ram air box and cone, sd ram air hood, 3800 pcm, AL 104's, 180 t-stat, sd headers, 3.4 pulley, aeroforce scanner, sweet wheels that gotta be putting an extra 30 horse to the ground
  2. #2 Re: Transmision won't go into gear
    Check the shifter linkage to the transmission.
    You can also try to push in the shift lock release.
  3. #3 Re: Transmision won't go into gear
    south dakota
    ok i will take a look. It looked fine from the top of the tranny where it connects but i will need to get a jack tomorrow to look at the rest. Shift lock didn't work when I tried either. I was kind of hoping that it would be a common problem :/
  4. #4 Re: Transmision won't go into gear
    my regal had a similar problem. turned out the shiftier rod was rusted up or corroded inside the shaft, spray lubed it up. all better.
    the release button moves a shaft inside the shaft of the shiftier on my regal. thats what needed to be lubed up. being your car has been sitting, this may be the same case for you.
  5. #5 Re: Transmision won't go into gear
    south dakota
    ignore the part about the jack from my last post. does not go under the car goes in through the firewall! mast have got a line mixed up when i looked the first time. Scottydoggs, that was done by pulling the trim or panels apart around the shifter?
  6. #6 Re: Transmision won't go into gear
    south dakota
    ok, so i happened to go outside and push my shifter straight down and the handle got pulled up like an inch off the shaft at some point, strange i thought. So got her fixed and thanks for the help!
  7. #7 Re: Transmision won't go into gear
    i took the console out. that way you can see how the whole thing works clearly.
  1. 3rd to 4th transmision issues
    By Hamnjelly in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2011, 05:09 PM
  2. transmision slipping
    By victorca1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2009, 09:06 PM
  3. transmision ??
    By french080 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-21-2009, 07:54 AM
  4. feels like a transmision slip...
    By 52 picup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-20-2008, 01:22 PM
  5. Transmision fluid burnt. Do i flush it?
    By joshb227 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-10-2008, 09:13 PM
