Thread: lucas transimission fix
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: lucas transimission fix
    SE Level Member RichCresci's Avatar
    Jul 2008
    anyone know how much a TCC solenoid costs with labor and parts?
    1999 GTP Sedan - 3" SLP Headers, K&N Intake, VS cam, poly mounts, ZZP pcm, 3.4" mod pulley, Thrasher shift kit, Pypes racepro, GMPP Handling kit + Trailing arms, Gauges(aeroforce scan, boost, oil psi)
  2. #22 Re: lucas transimission fix
    Nov 2008
    Heaven, compared to HERE
    not cheap...as they are located inside the trans (IIRC its inside a cover plate on the side...so don't have to take the tranny, so at least thats a plus)
  3. #23 Re: lucas transimission fix
    Banned
    Wichita Falls, Texas
    Technically you don't even have to drop the tranny to take the side cover off, but any shop you take it to isn't going to know that.
  4. #24 Re: lucas transimission fix
    I live here. UR LOSN's Avatar
    Rockford, IL
    Trannyman FTW!
  5. #25 Re: lucas transimission fix
    Jul 2008
    Germantown, Maryland
    what about the EPC solenoid, my brother was asking if we could probably reach it without dropping the trans
  6. #26 Re: lucas transimission fix
    Barksdale AFB, LA
    Quote Originally Posted by Quicklynx View Post
    All of the solenoids are in the same side cover.
    2009 Subaru Impreza WRX STI
  7. #27 Re: lucas transimission fix
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    You may be able to change solenoids without dropping the trans completely out of the car, but it will have to be almost dropped out in order to get the clearance needed to get the side cover off. If you get that far, you might as well change them all or get an upgraded valve body with the TCC revisions and change the solenoids, and also a new boost valve. FWD transmissions are not made to be easy to work on when in the car....
  8. #28 Re: lucas transimission fix
    Jul 2008
    thats a good idea, i'll look into them all, thanks for the info
    I like manuals better, haha, lighter and less of a hassle, although I've never worked on a fwd manual trans...
