I have a brand new transmission that appears to be from a 2005 GP. The Yellow colored data tag has the following info:
615CGB and W016P
GM P/N 24229076
Here's where it gets interesting... I want to put this trans in my 1999 GTP. I suspect that this is a Tap-Shift tranny from the brief info that I can find on Google but I think it still has 2.93 final drive.
I have a 2003 PCM and DHP PowerTuner for any differences that I encounter with gearing but will a tapshift trans work with a non-tapshift PCM?
I understand that there are valvebody differences with tapshift tranny's, how will they effect operation in my case?
Will the stock 1999 wiring harness be adequate to connect a 2003 PCM with a 2005 trans?
I also know that the cooler lines will not be compatible. Can I remedy that by buying cooler lines for a 2005? Maybe I can make an adapter on the lathe?
This trans has been put away dry for seven years now. How should I best wake up the beast? I know that all of the seals and clutches were installed with some fluid on them but is there any way to ensure that everything goes fine on start-up?
Thanks very much in advance for your help!
