Thread: Identify this Transmission??? Can it be made to work in my 1999 GTP?
Results 1 to 6 of 6
  1. #1 Re: Identify this Transmission??? Can it be made to work in my 1999 GTP?
    Mar 2013
    Colorado - USA
    So that 2005 Transmission is INSTALLED in my 1999 GTP. The trans has the quick-connect fittings and my stock 99' cooler lines are the threaded type - so they are not compatible without some adaptation. Can I use 2003 cooler lines to link this trans to my stock radiator on my model? How about 2005 lines? They are much cheaper but look a little different. What is the difference?
    How can I connect my 1999 radiator/cooler with my 2005 trans without breaking the bank?
    BillBoost37: Thanks for the install advice for the external shift switch - I placed it perfectly on the first try. No problems. THANKS!
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  1. Will a 2004 gtp transmission work with a 2000 gtp?
    By sseigtp in forum General Grand Prix Discussion
    Last Post: 08-13-2012, 09:27 PM
  2. will a 1998 gtp transmission work in a 2001 gtp???
    By glm859 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2012, 06:16 PM
  3. 2000 GTP Sedan In PA Needs Transmission Work $800
    By bosox27 in forum For Sale - Vehicles
    Last Post: 03-18-2012, 05:34 PM
  4. 1999 Grand Prix Transmission leak
    By sdilliha in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2010, 11:56 AM
  5. 1999 Grand Prix Transmission headaches...please help!
    By istorm70 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2010, 03:40 PM
