Thread: gear set, 4th gear hub, channel plate gouged! help!
Results 1 to 20 of 23
  1. #1 gear set, 4th gear hub, channel plate gouged! help!
    SE Level Member kawasaki22106's Avatar
    Ford City, Pennsylvania, United States
    OK so i tore my trans apart today and found one of my thrust washers was trashed between the gear and channel plate, my 4th gear hub was rubbing the chain gear. Both gears have some rash on them from this and the 4th gear hub has rash on it and also the channel plate. Any ideas on what caused this?!?! The chain and gear set was a 7/8th 2.93 ratio.....
    channel plate
    4th gear hub
    drive gear (this is where the bushing was trashed) i removed the retainer clip, it was installed.
    driven gear
  2. #2 Re: gear set, 4th gear hub, channel plate gouged! help!
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Edit...I take that back. If that pic was taken how you found everything there is a chance that with the bushing being destroyed on the drive gear that it has cause the driven gear to "walk" toward the driver side of the car causing some issues. Still wouldn't explain the interference between driven sprocket and 4th clutch hub.
    As far as the bushing that goes between the drive gear and channel plate I am going to have to stick with installation error. Did you even find remnants of the bushing? was is ever put in the trans? Without it, it's going to cause damage just like you have pictured.
    Additional Edit....Where is the drive sprocket retainer clip that holds the sprocket in place on the input shaft?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  3. #3 Re: gear set, 4th gear hub, channel plate gouged! help!
    i found everything gouged like this when i pulled the channel plate off. i removed the retainer clip it was installed, and yes i found remenance of the bushing so it was installed but decided it didnt want to be in there any more and committed suicide lol
    btw this was a tim king trans with only 1600 miles on it
  4. #4 Re: gear set, 4th gear hub, channel plate gouged! help!
    Hi John...
    Drive gear bushing IIRC is plastic. Pat said you guys found pieces of it, so it had been there at some point. If there wasn't enough trans goo on it to hold, it may have gotten mashed upon install. Unless the welds on the reluctor tore it up over time, tough for that to happen if the pin heads don't usually hurt it.
    4th hub to gear. Should not be possible with the plastic bushing there. Put them together outside of the trans and see if they hit. I bet they don't. Which means they must have gone in looking like that.
  5. #5 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    The bushing that goes in between the channel plate and drive gear is known to fall out of place during installation if you're not paying attention. I always use a big goop of petroleum jelly to make sure that the bushing stays oriented and in place during installation. If it was out of place or not seeded properly the bearing would have been destroyed shortly after first start up.
    Were the sprockets also purchased from Tim King. Because with the additional information about having the drive sprocket retainer clip in place they only way that I would see that the driven gear would have interference with the 4th clutch hub would be an issue with the specifications for the machining of the sprocket for the 4T65E application.
    No comment on Tim King.....other than I will never do business with him.
  6. #6 Re: gear set, 4th gear hub, channel plate gouged! help!
    no i purchased the chain and gear set from zzp and gave it to him. my trans had a hardened 4th gear hub from factory so he reused it.
  7. #7 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    Your driven gear is not machined properly IMO....Here are a couple pic for reference as to what it should look like. Notice that your spocket has a ridge right in the area where you are having the interferrence issue.
  8. #8 Re: gear set, 4th gear hub, channel plate gouged! help!
    You know Greg, some people label them by teeth. That way when the diff ratio changes..the writing isn't wrong.
  9. #9 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    Pic was stolen from the internet. Just showing the example of what the driven sprocket machine surface was supposed to look like.
  10. #10 Re: gear set, 4th gear hub, channel plate gouged! help!
    greg im not seeing what you are seeing....
  11. #11 Re: gear set, 4th gear hub, channel plate gouged! help!
    Use the outer set of holes as a reference point. On your ZZP high quality part..that bevel is right at the hole. On the other pic...it's been machined much further back
  12. #12 Re: gear set, 4th gear hub, channel plate gouged! help!
    got ya now..... well this sucks
  13. #13 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    In between the red lines you'll see that there is an extra ridge that should have been removed during the machining process. Which is exactly where the 4th clutch hub is rubbing on the driven sprocket. Green circles are what you should reference as far as the distance it should have been machined.
  14. #14 Re: gear set, 4th gear hub, channel plate gouged! help!
    Greg..you are informative...
  15. #15 Re: gear set, 4th gear hub, channel plate gouged! help!
    time to head to the garage and look at my 1" chain/gears and compare..... i am gonna check and see if the 4th gear hub is hitting as well like bill said so see if it happened now or was from earlier wear that tim didnt tell me about....
  16. #16 Re: gear set, 4th gear hub, channel plate gouged! help!
    there is clearance issues there for sure, my 1" gear fits fine but the 7/8ths rubs. so that explains the 4th gear hub but would this cause the drive gear to grenade the bushing and rub the channel plate? and is my 4th gear hub reusable or should i buy another one.....
  17. #17 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    Cause of the bushing to rub on the channel plate is going to be cause by install error IMO. If it falls out of place or is crushed during the install the bushing wont last 10 miles.
    Replace the 4th clutc hub. You're talking about a huge turbo build with a 1" GMR chain........why cheap out on a part you get can get new for $35.
  18. #18 Re: gear set, 4th gear hub, channel plate gouged! help!
    I say keep the 4th hub. Nothing ever touches it where you have that "mark" on it. It's not a structural or strength probably from the mark on it. Call it a character mark.
  19. #19 Re: gear set, 4th gear hub, channel plate gouged! help!
    Apr 2011
    Columbus, OH
    Fine Bill....keep it in there....How do the splines look on the other side of the 4th clutch hub. If there is signs of wear, for sure replace it.
  20. #20 Re: gear set, 4th gear hub, channel plate gouged! help!
    no signes of wear on the splines, take note to the close up pic of the 4th hub teeth though, i never seen one in person till now do they look ok? to me it looks like they got little marks in them but the marks are all uniform on every tooth....
  1. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    Last Post: 11-12-2012, 12:18 PM
  3. Channel plate gasket
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2012, 08:27 PM
  4. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
