Thread: gear set, 4th gear hub, channel plate gouged! help!
Results 1 to 20 of 23
Threaded View
  1. #2 Re: gear set, 4th gear hub, channel plate gouged! help!
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Edit...I take that back. If that pic was taken how you found everything there is a chance that with the bushing being destroyed on the drive gear that it has cause the driven gear to "walk" toward the driver side of the car causing some issues. Still wouldn't explain the interference between driven sprocket and 4th clutch hub.
    As far as the bushing that goes between the drive gear and channel plate I am going to have to stick with installation error. Did you even find remnants of the bushing? was is ever put in the trans? Without it, it's going to cause damage just like you have pictured.
    Additional Edit....Where is the drive sprocket retainer clip that holds the sprocket in place on the input shaft?
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  1. tranny wont shift into 3rd gear. please help where is my 3rd gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-20-2012, 11:49 AM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    Last Post: 11-12-2012, 12:18 PM
  3. Channel plate gasket
    By bull40dawg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-27-2012, 08:27 PM
  4. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
