Hey everyone,
I've got a bit of a conundrum here. I am replacing the clutch plates and according to the manual I should see a marking for down on the second clutch plate.
"Install the second clutch apply plate (716) into the second clutch housing (617) with the marking DN or DOWN toward the piston"
Trouble is I don't see any marking other than UP on the backing plate? My thought is maybe it is worn away so my question is how would I identify which side should be down without the marking?
It seems that it has a flat cut side which I assumed would be "down" and a rounded edge side which I figured would be a better face to match to the friction plate or "up" but I am having second thoughts....
any suggestions?
