these are the following things I have done with the car
1. oil change with new filter and Lucas oil treatment
2. Transmission pan drop service with new filter, Dex 6 fluid and Lucas Transmission Stabilizer
3. Cut out clogged Catalytic Converter and put in straight pipe with u-bend delete and new 02 sensor
4. New Fuel Filter
5. Listened to gas tank and heard Fuel pump IS coming on, but don't know if it is pumping correct pressure at all times
6. New Front Right wheel hub bearing assembly/ Wheel Speed Sensor
