Thread: Transmission won't engage
Results 1 to 18 of 18
  1. #1 Re: Transmission won't engage
    Quote Originally Posted by Peder View Post
    Yep. I don't understand it either. lol
    found these two posts for you. http://www.grandprixforums.net/p1810...cuit-5118.html
    P1860 - GM Forum - Buick, Cadillac, Chev, Olds, GMC & Pontiac chat
    it is possible to change the solenoids in the side cover with out fully removing the trans, you need to remove the d/s axle and then drop the sub frame on the d/s a bit as well. saw a vid on youtube who did it this way, (of course i cant find it now) of a guy who had it all broken down and apart, its best to change the harness as well.
  2. #2 Re: Transmission won't engage
    Mar 2013
    United States
    thanks Scottydoggs, I have seen that post and tried to unplug the trans connector to see if anything changed but no dice. also it went from shifting fine to zero all at once? seems a little different.
  1. ac won`t engage
    By kenjr in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-05-2013, 06:47 AM
  2. Drive won't engage - sometimes
    By BatmanBob in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2012, 08:15 PM
  3. AC Compressor won't engage
    By SJAndrew in forum General Tech Discussion
    Last Post: 04-01-2011, 11:06 PM
  4. Swapped motor, now transmission won't engage Park
    By oldschoolpontiacs in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-12-2009, 12:30 AM
  5. Transmission won't engage in D, but will with the paddles...
    By Edmonchuck in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2008, 12:10 PM
