Thread: need a little help
Results 1 to 5 of 5
  1. #1 need a little help
    Nov 2010
    Missouri
    I'm not 100 percent sure what happened to my car today if it was my transmission that blew or if it was an axle. When I started my car today and took off it felt like i was going to fast in 4 low kinda had that weird feeling. Well anyways I get about two. Blocks down the road and I hear a small grinding noise I came to a stop. The noise still there when I took off and all the sudden bam. I'm not moving the grinding is was worse so I through it in park and all the sudden my rpm and speed increases I shut off the car. I wait about 5 min. I start the car everything seems okay in park. Then I shift to neutral it does the same thing in park as in neutral. I shut off the car and got it home. 3,8 gTP no mods all stock. Does same thing in all gears when in park I move like I'm in neutral. Any ideas ??also sounds like rocks in a metal can
  2. #2 Re: need a little help
    Sounds like you lost your chain.
  3. #3 Re: need a little help
    Or possibly broke an axle
  4. #4 Re: need a little help
    Nov 2010
    Missouri
    The axles won't be to bad at all to replace. I have noticed that I have had a vibration when I'm at light throttle Around a corner. But not there when I'm at a steady speed
  5. #5 Re: need a little help
    Nov 2010
    Missouri
    I'll find out more in a few days though when it gets to the shop
