Thread: Rough idle when started
Results 1 to 9 of 9
  1. #1 Rough idle when started
    Feb 2013
    South Dakota
    I am not sure if this is where I am supposed to post this i'm new lol anyways, I have a 2000 grand prix gt with 213k some odd miles on it.... When I start it it idles really rough not sure how to explain it when first started it jumps for 700 rpms to about 900 really fast back and forth for about 5 - 10 seconds and then stops and every now and then it will randomly jump when idling and drop back down to where it about dies and than catches, also when I bought the car at 205k miles I changed plugs and wires and the crank censor and flushed trani
  2. #2 Re: Rough idle when started
    SE Level Member Ryan99639's Avatar
    Feb 2013
    Rockford
    mines doing that too I did plugs and wires, think I'm gonna try coil packs next
    BOOSTIN
  3. #3 Re: Rough idle when started
    Feb 2013
    South Dakota
    Mine has old msd ignition coils on it been meening to get stock ones..
  4. #4 Re: Rough idle when started
    Clean the throttle body and MAF sensor, aswell as the IAC.
    See if that helps.
    And I would just replace the MSD coils with stock ones, because MSD is junk.
  5. #5 Re: Rough idle when started
    Feb 2013
    Rockford
    how do u clean the iac is it just a plug? I haven't checked that yet
    BOOSTIN
  6. #6 Re: Rough idle when started
    St. Louis
    Also, what type/brand of spark plugs did you install? Hopefully they were stock irridiums or some copper plugs. The ignition system in these cars does NOT like platinum plugs, not matter how much the guy at Vatozone tells you they'll be fine.
    And to clean the IAC just remove it from the TB. 2 bolts IIRC. Clean the bore in the TB where it attaches, and then spray the crap out of the IAC itself. If that doesn't help then it's time for a new IAC. Usually cleaning one is just a stop-gap until you can afford/find time to install a new one.
    And do NOT use anything but approved MAF cleaner for the MAF itself. If you use brake or carb cleaner it will kill it. CRC is a good brand of MAF cleaner. And just spray it clean and let it air dry. Don't use a q-tip or anything on the MAF as you can break the tiny wires inside.
  7. #7 Re: Rough idle when started
    Feb 2013
    Rockford
    I've cleaned the maf with approved spray, and I have autolite 104s because this is the beginning of my build they are iridium , so I guess iac is next on my list, should I do that before coil packs?
    BOOSTIN
  8. #8 Re: Rough idle when started
    St. Louis
    I'd junk those MSD coils first, as they are known to cause issues. Then move onto the IAC if need be. Removing the coils from the equation will help in troubleshooting further.
  9. #9 Re: Rough idle when started
    Feb 2013
    Rockford
    new stock coils and new iac let's see what happens lol
    BOOSTIN
  1. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  2. Won't idle; missing above idle if you can get it started
    By jrece in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 11:24 PM
  3. Rough Idle
    By PTGsDaytona500GTP in forum General Tech Discussion
    Last Post: 09-01-2010, 10:48 PM
  4. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
  5. rough idle 02 gtp
    Last Post: 03-06-2010, 01:16 PM
