Thread: trans comes out gear on hard stop
Results 1 to 3 of 3
  1. #1 trans comes out gear on hard stop
    SE Level Member richduty455's Avatar
    Feb 2013
    sewell, NJ
    Ok so my first post for a question and its a doozie 2000 GTP with 100k on it......sometimes, not all times and it does it cold hot, night day, whenver randomly. When you come to a hard stop ususally is youre driving below 40 mph, the car feels like it comes out of gear and goes into neutral then bang slams back into gear. If you pull out before it comes to a complete stop is bangs hard, almost like a neutral drop....other than that the car runs great...all gears work fine..car pulls hard under WOT, just this problem....any takers??
  2. #2 Re: trans comes out gear on hard stop
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    fluid level ok or have you done a pan drop resently?
    97 Bonneville SE Not so much a 97 anymore
  3. #3 Re: trans comes out gear on hard stop
    Feb 2013
    sewell, NJ
    Quote Originally Posted by Nighthwk12 View Post
    fluid level are ok.....it started doing it so i did a fluid/filter changed.....still does it....fliud was clean....still clean and full.
  1. Hesitation then very hard shift accelerating from stop
    By GrandprixSteve in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2013, 02:42 PM
  2. 97 gtp trand shifting hard from 2nd to 3rd gear.update!!!! shifts hard in every gear?
    By Doug 97 gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2012, 12:18 PM
  3. 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    By shawnooohhh in forum General Tech Discussion
    Last Post: 02-11-2012, 10:44 AM
  4. Hard out of first gear
    By jaredbos 1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-11-2011, 12:14 AM
  5. hard shift into 3rd gear
    By gtpforever15 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2008, 02:02 AM
