Thread: hard shift into 3rd gear
Results 1 to 4 of 4
  1. #1 hard shift into 3rd gear
    Apr 2008
    Rockford, IL
    so just a couple of days ago my 97 gtp has started to shift vary hard from second to third. a week ago i changed the trans fluid to synthetic fluid and put a new filter. i am also waiting for my transgo shift kit to come. but the trans is stock until i get that shift kit in; but any insight of what else i should do for the hard shiffting? or whats causing it?
  2. #2 Re: hard shift into 3rd gear
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Check for trouble codes to see if you have a P1811 or any other codes trans related. On rare occasions the accumulator springs can break or the pistons can get stuck in the accumulator bore and cause a harsh shift. When you install the shift kit you will be able to inspect the accumulator parts.
  3. #3 Re: hard shift into 3rd gear
    Apr 2008
    Rockford, IL
    ok so i put the shift kit in, and it was alright for a couple hundred miles; doing its job well. then the ses light came back on and its slipping into third now. pcs problem? idk trannyman what do you think i should do?
  4. #4 Re: hard shift into 3rd gear
    Apr 2008
    Rockford, IL
    only slips at wot though; sorry
  1. Why is my 1st to 2nd shift so hard?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 04-26-2008, 08:35 AM
  2. hard shift between 1rst and 2nd
    By gp2004_compg in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2008, 06:56 PM
  3. Hey, where'd my 3rd gear go?
    By bigjim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-30-2008, 11:21 AM
  4. any top gear fans here?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-28-2008, 11:28 PM
