Thread: Tranny Problem
Results 1 to 11 of 11
  1. #1 Tranny Problem
    Jan 2013
    Arkansas
    I know I am new here but i know how forums work i have been a member of GAGT and newcelica for about 2 years. So please no nubbie pun.
    I just purchased a 2006 Pontiac Grand Prix base model. It has about 120k miles on it and has a very strange transmission problem. It will shift smooth and comfortable and never slip or shift hard. But if you get on it hard it will shift from 1st to 2nd as it is supposed to but then will not shift to any other gear until you let off the throttle then it will shift hard into gear and you can continue on. What may be causing this? NO SES lights.
    I was going to drop the pan and check for metal shavings and if none are present change the fluid and filter. Good idea or bad?
    Thank you to anyone that may be able to help.
  2. #2 Re: Tranny Problem
    GT Level Member Erik Adam Rodriguez's Avatar
    Sep 2012
    bridgeport,NY
    keep the shifter in drive
    02 grand prix gt- L67 swap, ZZP 1.0 pcm, thrasher CAI, SLP 2.5 catback, A/C delete, 02 emulator, poly dog bone mounts, 6000k projectors with CCFL halos, 12 in slotted front rotors, ported blower and intake, evap and EGR deleted, 12" kicker cvr with 1000 watt amp, alpine cda 9886 deck
  3. #3 Re: Tranny Problem
    What kind of mileage on it?
    Sounds like you might be seeing some slip from the 3rd clutches.
  4. #4 Re: Tranny Problem
    Jan 2013
    Arkansas
    120k miles
  5. #5 Re: Tranny Problem
    Jan 2013
    Arkansas
    If i just replace the transmission can i use any 4T65E transmission or do i need one from a newer grand prix? Or can i use one from a 99 Buick LeSabre it is a 4T65E transmission.
  6. #6 Re: Tranny Problem
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    It has to be from a new model. There were differences in the internal wiring and also slight changes in the valve body.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  7. #7 Re: Tranny Problem
    Jan 2013
    Arkansas
    What is required to swap for the 4T65E-HD transmission in?Once again thank you to everyone for your replies.
  8. #8 Re: Tranny Problem
    PCM tune and a new (different) PCM because you can't change anything on 06-08 cars.
    The HD trans is not better, it just have a few different parts and completely different gear ratio.
    You are going to have to find a 04+ base model transmission. I think the 04-05 GT NA cars even have the same as yours too, if you end up needing to replace it.
  9. #9 Re: Tranny Problem
    Jan 2013
    Arkansas
    Ok. I have done an engine swap before and rebuilt a manual transmission so i have a pretty good idea what i am doing on cars. On a scale of 1 to 10 how hard is it to pull the transmission in these cars?
  10. #10 Re: Tranny Problem
    1-10 for who? I think it's a 2 personally because it's counter clockwise loosens bolts and clockwise tightens them. Others would disagree.
    I wrote up a how to on trans swaps. If you search the word "ea sy" without the space and my user name, you should be able to find that and other write ups every quickly. Take a read through. Although as you can assume by the word I suggested you search one...I think all these things are eeasy. It's just some time and effort.
  11. #11 Re: Tranny Problem
    Jan 2013
    Arkansas
    Thanx Ill check it out.
  1. Possible Tranny Problem?
    By RickyRacer21 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2011, 03:31 PM
  2. 01 GTP tranny problem
    By jaegle2 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-16-2010, 01:33 AM
  3. Tranny problem!!!
    By Newfie83 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-14-2009, 04:12 PM
  4. Possible tranny problem?
    By isucyclones3 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-04-2009, 11:52 AM
  5. Tranny Problem
    By 2000GTP2708 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-24-2008, 02:48 AM
