Thread: Transmission Fluid in Antifreeze
Results 1 to 16 of 16
  1. #1 Transmission Fluid in Antifreeze
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    I came to the conclusion that I had some sort of tranny fluid leak the other day when I heard my transmission whining due to low fluid. So I did what everyone does, jack the car up, clean the underside with Brake Cleaner, start it up and wait. After about 10 minutes there it was.
    Leaking out of what seemed to be the heater core, dripping all the way down the firewall, then onto this Brake line:
    Never seen anything like it. So out of curiosity, I checked the radiator and there it was, strawberry milkshake madness:
    Having never seen this problem before, and after doing some research, it seems that the "transmission cooler" inside the radiator is damaged or broken. What are the next steps I should take to solve this problem?
    Thanks
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  2. #2 Re: Transmission Fluid in Antifreeze
    New radiator time.
    Then flush your coolant and do a trans fluid change, you dont want ANY coolant in the trans fluid, coolant will kill it.
  3. #3 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    I have an aftermarket Transmission Fluid Cooler as well. Could this have contributed to the problem?
  4. #4 Re: Transmission Fluid in Antifreeze
    Not likely. I good guess would be that the cooler tank cracked on the inside from age or getting bumped really hard.
  5. #5 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    Ya the cars getting old and has never seen cold temps like these Georgia cold fronts.
  6. #6 Re: Transmission Fluid in Antifreeze
    SE Level Member crashman's Avatar
    Perry Hall, Maryland
    New radiator time.
    Nope........................the ONLY way transmission fluid gets in there is through the heat exchanger in the radiator.
    "Time is a great teacher, but unfortunately it kills all its pupils."
    RIP 2000 GTP
  7. #7 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    Any reason why it would be pissing out the Heater Core?
  8. #8 Re: Transmission Fluid in Antifreeze
    Bad hose?
    Take a picture where its leaking out the heatcore.
  9. #9 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    Its pretty hard to get to with the phone, ill see what I can do.
  10. #10 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    Quick update. Found out that the leak was coming from the top of the coolant overflow tank, which was filled with tranny/antifreeze goodness. Drained the radiator, pulled off the thermostat housing, flushed the motor, this stuff is everywhere. Should i flush the Heater Core as well? And are there any suggestions on a degreaser or chemical I could run through the block just to be sure all the tranny fluid is out of it?
  11. #11 Re: Transmission Fluid in Antifreeze
    I'd be more worried about the coolant in the trans than the trans fluid in the coolant.
  12. #12 Re: Transmission Fluid in Antifreeze
    Donating Users Slappyn's Avatar
    Dec 2012
    Goldsboro, NC
    I had the same thing with my old truck. You should think about pulling out the torque converter since there will be strawberry slush in there even after you change the oil.
  13. #13 Re: Transmission Fluid in Antifreeze
    Atlanta, GA
    Hmm, never pulled a trans on this car. Havent had a chance to crack the tranny pan open. What do yall think about running some degreaser or simple green through the engine components? And whats the best place to buy a radiator online?
  14. #14 Re: Transmission Fluid in Antifreeze
    I would flush the coolant and refill it. Do it a few times if necessary.
  15. #15 Re: Transmission Fluid in Antifreeze
    SE Level Member harner's Avatar
    Apr 2012
    New Ringgold, PA
    I wouldn't run degreaser. Just flush your cooling system out with water. I bought a used radiator on ebay for cheap, works very good. Time to upgrade while it needs to be replaced.
    1998 Grand Prix GT Sedan - SOLD
    10 Camaro 2SS/RS | 94 TA | 87 IROC | 06 Silverado 1500
  16. #16 Re: Transmission Fluid in Antifreeze
    Dec 2012
    Goldsboro, NC
    Quote Originally Posted by sdavis11b View Post
    The trans is not hard. Dont run degreaser in there. Look at the junk yard or rock auto for a cheap radiator. Summit or ZZP for a high performance. Autozone or Advance auto for the cheapest decent/new radiator and if you go this route make sure to search for the forum on how to get the best price at Advance Auto. Swing by your local radiator shop and see what they have to say about the whole thing or give them a call if you dont have time to drop in. Talk to your local transmission shop about the whole ordeal with the trans. Usually they will either tell you to bring it in or give you some free advice.
  1. Transmission fluid leak
    By LowRidinCrew in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2012, 04:06 PM
  2. transmission fluid
    By Linebacker in forum General Tech Discussion
    Last Post: 05-17-2012, 08:25 AM
  3. transmission fluid
    By dave2002GP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2010, 09:01 PM
  4. What transmission fluid for 98 gtp?
    By silverPGP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-18-2010, 05:22 PM
  5. Transmission fluid
    By ChevMan92 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 07:54 PM
