Thread: Transmission problems and questions
Results 1 to 12 of 12
  1. #1 Transmission problems and questions
    SE Level Member overdose666's Avatar
    Oct 2011
    Houston, TX
    I have a 2003 Monte Carlo SS with the 4t65e
    For the past few months now I've been having intermittent shifting issues which are getting more and more frequent. At first it was just mildy hard shifts from time to time. The past few days I've been experiencing some extremely hard shifts into first and second. Checked the tranny fluid and it's still a nice pinkish red, but there's quite a bit of dark gray dust stuck to my dip stick which I'm assuming is clutch dust. I've been doing a lot of research on GPF and the Bonneville club forums and have found a lot of good information for total rebuilds but still have a few questions.
    The other day when leaving a restaurant I had on odd problem, when trying to get onto the main road from a dead stop the car drove about 4 feet without any problems, then all power to the wheels was lost, the engine rev'd to about 3500-4000 then the gears caught HARD, the wheels spun for a moment and jerked the car enough to hurt my neck , this was all happening with less than 15% throttle.
    While I dont have much experience with trannys this doesnt sound like an issue typically caused by bad clutch plates. Does any one have other ideas as to what the problem is, or what combination of problems is destroying my trans? I'm preparing to buy a master rebuild kit from triple edge which includes the frictions, and steels plus a new bonded style valve body spacer plate.
    4T65E Master Kit 2003+
    I would like to get some other opinions before i purchase this and take the tranny out of my daily driver...
    A few things I forgot to add, when idling at a stop sign or light, when the car is in drive I get an odd stutter and a good bit of vibration as though the car is trying to force itself to go, when its put into neutral it behaves fine. Also the majority of the time i only experience these issues once the trans has warmed up.
  2. #2 Re: Transmission problems and questions
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    scan it and see if it has a p1811 wont set the light but will set a code
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  3. #3 Re: Transmission problems and questions
    Jul 2012
    Chicago
    Try a shift kit before you go tearing that transmission out. Mine had similar behavior and the shift kit fixed it.
    The rough idle in drive could be other issues such as a dirty throttle body or IAC, etc.
    -Carl
  4. #4 Re: Transmission problems and questions
    get it scanned, if nothing comes up. could be as simple as a clogged filter, pan drop and filter change.
  5. #5 Re: Transmission problems and questions
    Oct 2011
    Houston, TX
    Quote Originally Posted by nos4blood70 View Post
    Can't shift kits increase the chance of a hard failure? As far as TB and IAC go I've been going through this since before I ported and polished my TB, while doing so I cleaned the whole thing out.
    Oh and i forgot to mention I'm approaching 140k!
    I live here. DirtDog's Avatar
    Jun 2012
    Quote Originally Posted by overdose666 View Post
    It depends on the shift kit u use. If u have the said 4t65e I would recommend the shift kit that TEP sales. The one that is a combo kit.
    Sent from my DROID RAZR using Tapatalk 2
  7. #7 Re: Transmission problems and questions
    If the PCS/EPC is the issue then the shift kit would bandaid/help with that and keep you from setting the P1811 code. When the PCS begins to give trouble, it'll often set only the P1811 and cause harsh shifts.
    If you are rebuilding, I'd also suggest sending your valvebody/channel plate to Dave and have it gone through. When you get it back, it's bolt on and that saves a lot of questions/time/aggrevation.
  8. #8 Re: Transmission problems and questions
    Oct 2011
    Houston, TX
    Went by advance auto and had it scanned, nothing new came up
  9. #9 Re: Transmission problems and questions
    St. Louis
    I don't know if Advanced Auto's scanners will read transmission codes. I've had issues with that around here as well. Last time I just took it to a trans. shop and had them scan it for me.
  10. #10 Re: Transmission problems and questions
    Oct 2011
    Houston, TX
    What can i expect to be charged? Only quote I've ever gotten for a scan was $85 from a local dealership.
  11. #11 Re: Transmission problems and questions
    Get the car to do the issue. Don't turn it off and have it scanned. Many trans codes will reset in the current status when the ignition is cycled. And the Advance scanners usually don't scan history codes.
  12. #12 Re: Transmission problems and questions
    Aug 2012
    VA
    To add to this topic, my car was having a lot of the same problems. Hard shifts in first and sometimes second, you could really feel it clunk down into the next gear. This was an intermittent problem for about 2 or 3 months, and it was fine at highway speeds. However, my problem steadily deteriorated over the last few days. First I started getting shaking when in reverse about three days ago, then the last two days it was having real problems getting out of first, revving up to 3.5-4k and sticking, requiring multiple pumps of the gas to kick into second. Today it finally gave up, and after refusing to leave first it wouldn't engage at all eventually, just revving up to the same 3.5-4k without movement. Having it towed to a shop now, I'll add in what I find out to see if it can help you at all.
    Edit for model: 2007 GP Base, no mods. 103k.
  1. Transmission problems. Can anybody help?
    By mrbee in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2012, 10:41 AM
  2. New Guy here few questions, transmission
    By thanospl in forum General Tech Discussion
    Last Post: 08-03-2010, 09:47 AM
  3. My Transmission questions???
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-26-2009, 12:55 PM
  4. have 2 transmission questions
    By 98GTPON22s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2009, 05:17 PM
  5. Transmission questions.
    By ChvyTrcksFrdScks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 07:11 PM
