Thread: need help!!no shift cold
Results 1 to 5 of 5
  1. #1 need help!!no shift cold
    May 2012
    NW lower Mi.
    hi everyone i am relatively new here. I have a 4t65e tranny,recently did a fluid/filter flush and a transgo shift kit,shift solenoids,pcs,iss.now I have no shifting cold till she is warmed up,then she works great with the exception of tcc kicking out at 55 for no apparent reasonmy first thought is to r&r the damned thing,but wanted to see what other thoughts are out there,thanks!!
  2. #2 Re: need help!!no shift cold
    how high are your miles? were these problem there before the flush? and you tried to fix them by flushing the trans? or they showed up after the flush?
    flushing the trans with high miles and no service prior are a death sentence.
    good chance you just killed the trans. ( if you did the above)
    i'd drop a quart of fluid out, and add a quart of lucas trans medix, or similar product and pray it holds together.
    GTP Level Member rperry435's Avatar
    Oct 2011
    MI
    45+ mph tcc lockup kick in and out is early sign of failure
    Sent from my SPH-L710 using Tapatalk 2
    '04 CompG - 3.6MPS - 104s - FWI - TOGS - w/14"SlimFans - SLP RR' s - 180HF Stat - TEP SK - Aluminum Oil Pan - 4thGen ZZP Wires - LS7 Lifters - AeroForce - AEM WB - HPTuners - FBSS Air Ride
    ASE & State Certified Auto Electrical Tech
  4. #4 Re: need help!!no shift cold
    May 2012
    NW lower Mi.
    well, thanks,this helps me make my decision,new tranny goin in asap!!I just wasn't sure if it was in the valve body.
  5. #5 Re: need help!!no shift cold
    Funky shifting can also be a sign of a bad maf or tps, even the wiring to it.
    although if you had all that stuff swapped, it has me thinking you had other issues. and of course to get to the ISS the channel plate/case cover had to be off and a gasket or improperly torqued bolt in the area can also cause some issues.
  1. cold weather brings cold engine
    By Garrett Mofford in forum Engine
    Last Post: 12-31-2012, 08:45 PM
  2. Been Cold
    By wlmrt6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-09-2010, 10:36 PM
  3. Cold Air
    By TallassJonG in forum 5.3L V8 (LS4)
    Last Post: 12-05-2009, 07:10 PM
  4. hello from cold ny
    By ASCStinger in forum Introductions/Noob Questions
    Last Post: 01-11-2009, 12:33 PM
  5. Cold Air
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-24-2008, 12:15 AM
