Thread: tranny wont shift into 3rd gear. please help where is my 3rd gear?
Results 1 to 13 of 13
  1. #1 tranny wont shift into 3rd gear. please help where is my 3rd gear?
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    tranny wont shift into 3rd gear. It won't shift into third at all please someone help I just did a filter and oil change and nothing helped.
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    http://www.grandprixforums.net/chugging-54738.html this is my, "i lost 3 rd gear" story. sorry for your loss.
  3. #3 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    Sep 2011
    palm harbor florida
    That thread is confusing. So maybe one of my sensors are bad because all the gears are perfectly fine.
  4. #4 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    if you no longer have 3rd gear, like it screams in second till it hits 50 mph, you let off the gas it then catches OD your trans is shot, and needs to be rebuilt, or replaced.
    if all you do is drive around town it may last a while. but its the end of the road for it.
    mine started out chugging in 3 rd gear at light throttle, ( around 30 to 34 mph) then it threw a code for a pcs and tcc. then one day, no more 3 rd gear. i put a used tranny in.
  5. #5 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    Sep 2011
    palm harbor florida
    it kinda makes a clicking noise at 30ish. like my car tops out at 95 it wont go past 2nd gear at all
    GT Level Member Utter99's Avatar
    Warsaw indiana
    Yeah bud sorry to say it time to rebuild or swap a known good one in .
    MY LUGNUTS REQUIRE MORE TOURQE THAN YOUR HONDA PUTS OUT!!!
  7. #7 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    Sep 2011
    palm harbor florida
    so there is no way it could be any of the sensors or solenoids?
  8. #8 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    not a chance. put a fork in it, its done.
    Someone doesn't want to face the truth. Unfortunately seems like your tranny is done..get a junkyard trans or built if you like and slap it in.
    04 Comp G.
  10. #10 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    Sep 2011
    palm harbor florida
    i dont want to face the truth of putting a new trans into my CAR IN MY GARAGE !!!!!. I find it hard to belive that not even oneof the sensors could be bad or anything
  11. #11 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    Sep 2011
    palm harbor florida
    Does someone have a tutorial on how to build a trans?
  12. #12 Re: tranny wont shift into 3rd gear. please help where is my 3rd gear?
    a bunch of guys have re built there own transmissions here. its a lot cheaper if you can do all the work. there are a few posts here that go over building a trans, you will need some special tools, and also need to send at least one part out to be re worked as well.
    Its not much cheaper after buying the parts and tools.
  1. Grand prix wont shift out of first gear until transmition is warmed up.
    By superluk9000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-11-2012, 07:17 AM
  2. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  3. Tranny takes a while to shift into 2nd gear
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-19-2010, 01:57 AM
  4. Wont shift into 4th gear
    By youngmcse in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 05:23 AM
  5. wont move in any gear
    By Thut420 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2009, 09:05 PM
