Thread: Transmission fluid change
Results 1 to 20 of 21
  1. #1 Transmission fluid change
    Aug 2008
    Long Island, New York
    This is gonna make me look really stupid, but i have never changed the transmission fluid on my car before, and I know where the drain plug is but I still am puzzled about where and how to put in the new fluid. Once again I feel stupid posting this but if someone could help me out it would be nice!
  2. #2 Re: Transmission fluid change
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    These transmissions do not have a drain plug, you have to unbolt the lower pan and leave a few bolts in and let it drain and then remove it. You will then have access to replace the filter. To fill the trans there is a dipstick that is towards the rear of the engine compartment with a red handle and once you pull out the stick you will need a skinny funnel to add fluid in the tube.
  3. #3 Re: Transmission fluid change
    Aug 2008
    thanks trannyman, ill do that.
  4. #4 Re: Transmission fluid change
    Aug 2008
    what do you think is a good transmission fluid i should use?
  5. #5 Re: Transmission fluid change
    GXP Level Member Zef_66's Avatar
    PA
    Quote Originally Posted by 2000GTP View Post
    Anything Dexron VI rated is going to be a decent fluid. For me, I picked up some Valvoline Dexron VI fluid because it is a full synthetic.
    2001 GSE
  6. #6 Re: Transmission fluid change
    Fort Wayne, IN
    Yep Dex VI is a drop in replacement and a synthetic fluid and is a better fluid than the original. The fluid that came in the car from the factory was Dexron 3 which is fine to use also and is cheaper.
  7. #7 Re: Transmission fluid change
    Aug 2008
    yeah ill go with the dexron VI
  8. #8 Re: Transmission fluid change
    Aug 2008
    is the dexron VI ok to mix with the dexron III in the tranny because i read something that said you cant drain all of the fluid, because some is in the torque converter. How would you go about getting this fluid out of there? or should I just get the most of the fluid out, and leave the leftover dexron III in the converter and mix them?
  9. #9 Re: Transmission fluid change
    Barksdale AFB, LA
    Dex VI and Dex III can mix. It's fine.
    Lol, I'm curious. You said you knew where the drain plug was. What plug were you talking about.
    2009 Subaru Impreza WRX STI
  10. #10 Re: Transmission fluid change
    Aug 2008
    Quote Originally Posted by Sabrewings View Post
    haha no sorry i was wrong about the drain plug... i was thinking of my parent's car
  11. #11 Re: Transmission fluid change
    Banned
    New Port Richey Florida
    There's 20 bolts on the trans pan. To avoid a mess take one corner of the bolts loose to the point were there is like 1-2 maybe 3 threads holding them in the trans pan. Then take a flat head screw driver and GENTLEY!!!!!!!! pry that side of the pan down. It might stick to the gasket. If you do this you'll avoid dropping the pan or making a MASSIVE mess of trans fluid in the drive way. Oh I forgot the pan bolts are a 10mm head My fault
  12. #12 Re: Transmission fluid change
    Aug 2008
    ok, is there a specific torque rating i should put the bolts down to?
  13. #13 Re: Transmission fluid change
    GTP Level Member Scimmia's Avatar
    QCA, IA
    10 ft/lb. Much more, and the bolts will break. I've even broken one at that rating.
    2001 Buick Regal LS - Almost Stock
  14. #14 Re: Transmission fluid change
    Barksdale AFB, LA
    Quote Originally Posted by Scimmia View Post
    Because that's not the factory spec. Factory spec is about 90 in-lbs. 10 ft-lbs is 120 in-lbs. You went 33% over what their spec is.
  15. #15 Re: Transmission fluid change
    QCA, IA
    The factory service manual would disagree with you.
    Oil Pan to Case
    Ref. No. 23
    Qty 20
    Size M6x1.0x18
    Metric 14 N·m
    English 10 lb ft
    As would the ATSG manual.
    25. Install the bottom pan onto the transaxle case, as shown in Figure 206.
    26. Install the 20 bottom pan bolts and torque the bolts to 14 N.m (10 lb.ft.).
  16. #16 Re: Transmission fluid change
    Barksdale AFB, LA
    For whatever reason, the GM SI manual says 90lb-in for 2003 and on, and that's what I was going by. I guess GM eventually realized the bolts were breaking.
  17. #17 Re: Transmission fluid change
    Aug 2008
    Oil Pan to Case
    Ref. No. 23
    Qty 20
    Size M6x1.0x18
    Metric 14 N·m
    English 10 lb ft
    Thats the oil pan to case torque spec it says
  18. #18 Re: Transmission fluid change
    Aug 2008
    f*** my torque wrench only goes down to 25 ft lbs
  19. #19 Re: Transmission fluid change
    Barksdale AFB, LA
    Don't have a in-lbs torque wrench?
  20. #20 Re: Transmission fluid change
    Aug 2008
    nope... just bought my torque wrench too. i wanted to get that 1 because i was gonna b doing my tires n stuff and i knew the lug torque was 100 ft-lbs
  1. Change Oil Soon Light
    By thermanlee in forum General Tech Discussion
    Last Post: 04-29-2009, 08:47 AM
  2. anyone ever change a gt to a gtp
    By e56505 in forum General Tech Discussion
    Last Post: 02-18-2009, 12:12 AM
  3. Impossible......to change
    By blackheart in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-21-2008, 07:26 AM
  4. How do you change you fog lights
    By mrkingkong in forum Off Topic Discussion
    Last Post: 08-11-2008, 03:26 PM
  5. Transmission Fluid Thermostat
    By Zef_66 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-14-2008, 08:49 AM
