Thread: Transmission Solenoids
Results 1 to 3 of 3
  1. #1 Transmission Solenoids
    GT Level Member japslpr's Avatar
    VA Beach
    Will the Pressure Control Solenoid Bosch sensor for the 03-up transmissions work in the 99 to replace the Holley sensor?
    431 Solenoid, EPC (4T65E) (Holley).......................................... ........................................ 1 97-02 84431G 5A-186
    431 Solenoid, EPC (4T65E) (Bosch)........................................... ...................................... 1 03-Up 84431H 5D-186
    Jae Harris: 1999 GTP, PARTED OUT
    1997 GTP: K&N 9", Stage 3 Gen 3, ZZP Hub w/ 3.25, S/S Headers, T&D Split Ratio RR (I-1.6, E-1.7), DHP 1.0, BEAR Big Brake Kit, 17x9 Cobra R's, GMPP Strut Towers F/R, Stage 1 Custom Cam
  2. #2 Re: Transmission Solenoids
    GTP Level Member Scimmia's Avatar
    QCA, IA
    No, 03+ uses a different design. They are not interchangeable according to the ATSG update manual.
    2001 Buick Regal LS - Almost Stock
  3. #3 Re: Transmission Solenoids
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    I believe it will physically fit BUT will not work correctly so dont try it. The spring behind the valve is different and the pcm tables are different and not worth the hassel. I have been using Borg Warner PCS for the 97-02s since they came out a few years back and have never had one fail so I would suggest going that route.
  1. Transmission questions.
    By ChvyTrcksFrdScks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2008, 07:11 PM
  2. s1x and built transmission
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-06-2008, 04:56 PM
  3. Interesting Transmission
    Last Post: 06-25-2008, 11:23 AM
  4. Does the trans need to be dropped to swap out shift solenoids?
    By bminior in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-08-2008, 08:59 AM
  5. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
