Thread: Loud clunking sounds like plastic hitting plastic
Results 1 to 3 of 3
  1. #1 Loud clunking sounds like plastic hitting plastic
    May 2012
    Where winter never ends
    When driving normally the tranny shifts great nothing is wrong. When under WOT and when the RPMs go above 4500 sometimes a loud clunking will occure. I can feel it in the gad pedal, it vibrates.
    It happens most of the time when I am going hwy speeds and floor it. The RPMs will rise like normal, hit 4500-5000 and then the clunking starts until after the shift where its normal. There is no loss in speed, no loss in power, no KR when this happens, wideband stays around 11.7 (WOT AFR). I have checked the fluid its fine.
  2. #2 Re: Loud clunking sounds like plastic hitting plastic
    St. Louis
    Might be a CV joint on its way out. Take a look at both axles and see if the inner or outer boots are split and slinging grease. Sounds like something out of balance in higher rpm's.
  3. #3 Re: Loud clunking sounds like plastic hitting plastic
    May 2012
    Quote Originally Posted by FordMan77 View Post
    Now that you mention it. I think you may be right. Ill get the car up on stands this weekend and check.
  1. DIY: Plastic gas tank upgrade
    By OH4CompG in forum How To Write-Ups/Tech Tips
    Last Post: 06-04-2013, 12:26 AM
  2. plastic engine cover - 5.3
    By gilligan in forum 5.3L V8 (LS4)
    Last Post: 04-25-2011, 08:13 PM
  3. plastic enginecover
    By Royalblue in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2011, 05:41 PM
  4. Plastic elbow
    By Coolride in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 06:47 PM
