Thread: Grinding noise after pan drop?
Results 1 to 6 of 6
  1. #1 Grinding noise after pan drop?
    May 2012
    Burlington, Wisconsin
    So, dropped my trans pan earlier to change the filter and put new fluid in. Dropped the pan, cleaned it, cleaned the bolts, put them back on, filled with a little less than 5 quarters of transmission fluid. Now, it seems like there's a grinding when shifting from 1st to 2nd and 2nd to 3rd. It's noticeable at first then goes away as I raise RPMs. This car is killing me. Any clue what it might be?
    1998 GTP Sedan: Gen III, Speedy Daddy Headers, SLP Catback, Magnaflow High Flow Cat, Open Cone Intake, Autolite 104s, Debadged, more to come!
  2. #2 Re: Grinding noise after pan drop?
    antioch ill
    you should prolly sell it
  3. #3 Re: Grinding noise after pan drop?
    You sure there is enough fluid?
    Did you check the dipstick with the car running and everything hot? Because a normal pan drops takes atleast 7-8 quarts.
  4. #4 Re: Grinding noise after pan drop?
    May 2012
    Quote Originally Posted by Matt Palm View Post
    Was planning on it until this came up. Now I need to fix this and throw more cash into it before I sell it lol.
    I checked with the car after being parked for a while. I'll go heat it up and check again. If that's the problem you just made my night.
  5. #5 Re: Grinding noise after pan drop?
    May 2012
    Added more fluid equalling 6 quarters. Problem seems to be fixed. I'll add another quart tomorrow just to be sure. Thanks FFDP!
  6. #6 Re: Grinding noise after pan drop?
    you should need 7 to 8 to fill it back up.
    re check it warm, and on flat level ground. dont over fill it.
  1. Grinding noise when going 30 and up!
    By rbrown81 in forum General Tech Discussion
    Last Post: 11-06-2011, 08:43 PM
  2. Grinding Noise
    By EJOUIE in forum General Tech Discussion
    Last Post: 10-08-2011, 11:28 AM
  3. grinding noise
    By BoostnBlackGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-26-2011, 11:28 AM
  4. grinding noise.
    By BoostJunki3 in forum General Tech Discussion
    Last Post: 01-03-2011, 11:03 AM
  5. new grinding noise
    By offroadfury6 in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2010, 08:07 AM
