Thread: harsh shift + brown fluid.. problem?
Page 4 of 4 FirstFirst ... 234
Results 61 to 73 of 73
  1. #61 Re: harsh shift + brown fluid.. problem?
    Donating Users kind153's Avatar
    Pittsburg, KS
    halp!
  2. #62 Re: harsh shift + brown fluid.. problem?
    maf can do that, or a vac leak. the check engine light come on?
    sounds like the trans got hot and started to act up again. bleed and top off your coolant as well, that could be the temp spike.
    these engines typically will get hot in traffic or stop and go driving, and on the open road drop back to a cooler temp.
    my regal runs at 1/4 on the temp, and as high as 1/2 way. back and fourth all the time. i have no numbers on my gauge, like your gp.
  3. #63 Re: harsh shift + brown fluid.. problem?
    Pittsburg, KS
    thank you scottydoggs!
    i just scanned for codes..no codes.
    what does acting up in hot conditions for a transmission mean? I searched and the term PCS solenoid comes up a lot. could it be it?
  4. #64 Re: harsh shift + brown fluid.. problem?
    Quote Originally Posted by kind153 View Post
    IT IS BACK.......... on my way from work it did the same thing but at a lesser degree. The engine temp was about a quarter higher too.(relevant?)
    We just had a thunderstorm so I had to park somewhere else, and I drove it to my usual spot and it did not do it.
    I had to drive a short distance (1/4 block) again afterwards, and after starting the rpm surged about twice.. 800-1500-800-1500-then 800 stable. I'm not sure this is relevant as well.
    Could a computer cause a hard shifting as well?
    I checked the ATF and it still looks pink.
    if its chugging at light throttle, ( driving in any gear) thats the pcs going bad.
    if its slipping or shifting hard it could be cause it got hot.
    external trans cooler may help some more.
    we all knew you were on thin ice to start with having dark burnt fluid. my fluid was like that and it blew. i lost 3 rd gear. got a used one put in.
  5. #65 Re: harsh shift + brown fluid.. problem?
    Nov 2008
    Waterloo, Iowa
    let your car warm up, check tranny fluid in park at idle, add trans fluid if needed. i just did that fixed my slipping and hard shift problems
  6. #66 Re: harsh shift + brown fluid.. problem?
    Pittsburg, KS
    OH that thin ice...........
    AFAIK it doesn't chug. just shift HARD at higher rpm. even with a light throttle.
    why does it hard-shift only when hot? would adding lucas help any?
  7. #67 Re: harsh shift + brown fluid.. problem?
    you put a bottle in already didn't you?
  8. #68 Re: harsh shift + brown fluid.. problem?
    Pittsburg, KS
    I'm afraid I didn't.. should I now?
  9. #69 Re: harsh shift + brown fluid.. problem?
    you would need to remove a quart of trans fluid if its full now. you dont want it over filled.
    if you have a long thin tube, you can siphon out a quart, the hose needs to be long enough to go down the dip stick tube hit the pan and then to the ground, into a bottle.
    or crack the pan and let some drain out.<<<<messy.
    then add a quart of lucas.
  10. #70 Re: harsh shift + brown fluid.. problem?
    Grand Rapids, MI
    hmm. Lucas is good, it's worked some wonders with my trans. I use it with every pan drop I do.
    And for hard shifting, if you can't remedy it, that's one of the "common fixes" that a shift kit can provide. As well as slow shifting fyi.
  11. #71 Re: harsh shift + brown fluid.. problem?
    Sep 2012
    Charlotte
    Quote Originally Posted by brandonl2000 View Post
    Just inherited a 2000 GP SE with 139K miles. It's experiencing the same symptoms as the OP. Hard shifting but only sometimes, often goes away on restart, but has the whine always. I'll drop the pan and change the filter and fluid regardless. While I'm down there, what's this shift kit? I couldn't find anything about it.
  12. #72 Re: harsh shift + brown fluid.. problem?
    Pittsburg, KS
    oh i forgot to update.. adding the stop slip appears to have fixed my problem!
  13. #73 Re: harsh shift + brown fluid.. problem?
    Grand Rapids, MI
    Well...your transmission is hydraulic. It uses fluid to shift from one gear to another. There are accumulators with springs in them for when you shift. It's very easy to get to and when you change these springs, you add a shift kit. It firms up your shifts etc etc etc. There are plenty threads about it. I have 3 in my favorites regarding install.
    There should be more info if you look.
    Anything I can help with let me know.
  1. Brown trans fluid, drain and refill?
    By KZOO3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2011, 07:28 PM
  2. Tranny shift problem
    By monsterjam5000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2010, 02:39 AM
  3. Shift Problem?
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2009, 02:30 PM
  4. shift problem, need advice
    By spassytaz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-16-2009, 06:37 PM
  5. shift kit problem.
    By 00pontiac1971 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2008, 06:47 PM
