If you are talking about pulling the valve body to replace the line and boost valves that come in the kit:
You have to remove the wire harness first, then the pump bolts (all but the silver one...leave that one!). Remove the pump. Then remove the pressure switch. Then remove the bolts from the VB. Draw a picture of it because the bolts are different lengths and need to go back where they came from...same with the pump bolts. The valve body should now come off. Watch out for the check balls! You do realize that you are going to need new gaskets for the VB right?
