Thread: replacing my trans - what else when I'm there?
Results 1 to 2 of 2
  1. #1 replacing my trans - what else when I'm there?
    Denver
    I'm getting a TEP rebuilt unit in the next month or so. I will be dropping iot from below.
    Dave mentioned replacing my radiator (due to potentially clogged trans cooler).
    What else should I do when I'm "there"?
  2. #2 Re: replacing my trans - what else when I'm there?
    Dec 2011
    Southern Wisconsin
    I would highly recommend using an aftemarket trans cooler and just bypass the radiator cooler. Dave is right in his concern, and no amount of flushing with not so cheap trans fluid will guarantee no contaminants. Mounts also come to mind if you have it down, much easier to replace them like that. Maybe plugs too since from underneath, with no trans, should be easy to get to the back ones.
  1. Should I try replacing my PCM?
    By 50Coupe in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-28-2011, 04:17 PM
  2. Replacing Engine and Trans Mounts. Part Numbers?
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2011, 08:08 PM
  3. Replacing CV shaft and trans fluid pouring out
    By ggsz28 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-03-2011, 12:51 PM
  4. replacing my a4 - gtp or gxp?
    By burninator in forum Off Topic Discussion
    Last Post: 06-30-2010, 06:50 AM
  5. Need troque specs, replacing trans
    By GPspool in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-15-2010, 06:18 PM
