Thread: New trans install question
Results 1 to 5 of 5
Dallasneon New trans install question 07-25-2012, 10:52 PM
MoarkatsINmuhtrailer Re: New trans install question 07-25-2012, 10:53 PM
BillBoost37 Re: New trans install question 07-26-2012, 05:49 AM
Dallasneon Re: New trans install question 07-26-2012, 12:31 PM
BillBoost37 Re: New trans install question 07-26-2012, 12:36 PM
  1. #1 New trans install question
    Keller,TX
    I just had my newly built trans shipped to me and I'm ready to do the install. The builder shipped the trans with the torque converter mounted but the trans and TC are completely dry (no fluid). He told me to not remove the torque converter to fill it, just start the car in neutral and add fluid as the level drops.
    2 questions:
    Is this an acceptable way of doing it?
    How much fluid does a bone dry trans and TC hold?
    Thanks in advance.
  2. #2 Re: New trans install question
    Ohio
    should be 13.X quarts total fill..so 3 gallons and another quart-quart and a half
  3. #3 Re: New trans install question
    I have always heard you should prefill a TC. however I do know a couple guys that didn't.
    To compromise on that, I'd install the trans dry.. then fill with 8 quarts. (8 is approximately a pan drop for service amount). Then fire it up and fill to the top of the hatches, runt it through the gears and check the level.
  4. #4 Re: New trans install question
    Keller,TX
    Sounds good, thanks guys.
  5. #5 Re: New trans install question
    Most likely the suggest you don't remove it, because it can sometimes be a pain to ensure it's back on teh stator properly w/o hurting seals etc.
  1. HV3 install Question
    By Empirecrzy241 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2010, 09:35 PM
  2. FIPK install question
    By dgs02gtp in forum Introductions/Noob Questions
    Last Post: 07-31-2009, 12:04 PM
  3. Homemade FWI Install Question
    By High Rolling GTP in forum General Tech Discussion
    Last Post: 02-01-2009, 08:51 AM
  4. Jacking points during trans install?
    By nlinesk8s in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2008, 07:33 AM
  5. Iron Indian Trans Install (Pictures)
    Last Post: 03-18-2008, 04:46 PM
