k fellas....'00 GTP . my tranny line started leaking the other day and i'm trying to find out which line it is but i'm not having much luck looking it up online. the line i need to replace is the line comin directly out of the bottom of the tranny and points straight to the ground. it then runs along the bottom of the rad and then threads into the bottom of the rad (not the upper line). is that line pressure or return? i ordered a line for an '00 GTP the other day and when it got here, all it had were the plastic clips on it. both my tranny and rad are threaded and i'm having a hard time getting the right line from the dealer. the '97 lines are threaded on both ends but they are a 2 piece line.
