Thread: 03 tranny, convert to HD or not?
Results 1 to 8 of 8
  1. #1 03 tranny, convert to HD or not?
    SE Level Member Stephen Shaw's Avatar
    Apr 2012
    I got two transmission, ones out of a 03 GP but is non-hd, the other is out of a 99(I think) GTP and is HD of course. From what I was reading the 03 is a better transmission?
    So my question is, should I use the 03 tranny and do a HD swap with it for my Top Swap I'm doing? or just throw the 99 tranny in and call it a day.
  2. #2 Re: 03 tranny, convert to HD or not?
    what year is the car
  3. #3 Re: 03 tranny, convert to HD or not?
    Apr 2012
    the car it will be going in is a 03. maybe I should reword this... I'm doing a top swap on a 03 GP GT, I have a full parts 99 GTP. I was going to put the HD tranny from the GTP in the 03, but I read someone that the 03 trannys are stronger? So should I take the diff of the donor tranny and put it on the 03 tranny?
  4. #4 Re: 03 tranny, convert to HD or not?
    The trans info you need to know:
    An 03 is different than the rest the valve body and channel plate are not the same, not compatible.
    There are a few threads (search on me) about putting an 03 into an non 03 car by swapping some pins.
    You can definately put the HD diff into your 03 trans, ensure you can program the gear ratio change, if there is a change. The end result would be 3.29 gearing. (I say if because the beer is starting to keep me from remembering what your 03 ratio is stock)
    The passenger axle would need to be swapped over as well. The HD diff is longer and therefore the axle is shorter than the non-hd.
    There are a few updates that GM made for the 03 year. Problem there is.. what was your car's production date? I've seen 10/02 and 11/02 prod dates on cars and the 4th clutch shaft was not hardened at that point. So an 03 car might not have all the upgraded parts. If the trans is out, it's worth a set of channel plate gaskets to find out.
    Hope that info helps out.
  5. #5 Re: 03 tranny, convert to HD or not?
    Apr 2012
    that does, thanks. I'm going to start learning more about auto trans very quickly, I can tell! lol
  6. #6 Re: 03 tranny, convert to HD or not?
    Apr 2009
    Fort Worth TX
    Always trust your RPO codes.
  7. #7 Re: 03 tranny, convert to HD or not?
    Apr 2009
    Fort Worth TX
    Here's the build info: Hold on they're chopped.
    There we go. I always wanted to get this info and post it. Someone probably already did though.
  8. #8 Re: 03 tranny, convert to HD or not?
    Apr 2012
    That's great info, Thanks Rico.
  1. Convert 4t65e to HD
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-11-2010, 09:36 PM
  2. Convert a GT to S/C
    By Brammer in forum General Tech Discussion
    Last Post: 05-02-2009, 08:15 AM
  3. 97 Grand Prix SE convert.
    By DDPeppa in forum Visual/Body Modifications
    Last Post: 03-13-2009, 02:18 PM
  4. Convert a GP to battery power. Could it be done?
    By Deezul_AwT in forum General Tech Discussion
    Last Post: 09-03-2008, 09:24 PM
  5. Convert to alcohol
    By archemedes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2008, 06:59 AM
