Thread: Help 4t65e HD problems
Results 1 to 3 of 3
  1. #1 Help 4t65e HD problems
    Jul 2011
    MS
    Had trans rebuilt Oct 2011 slipping in all gears. One month later it was making grinding noises. Repair shop went through it and said differential was bad. Two months later same problem diff was again replaced. One month later same problem, It has been at the trans shop for two months now. This is a '99 GTP I found this is a unique trans to this year of car the shafts have a larger spline and step down. so nothing is interchangable. Found a GM rebuilt but came to find out the shafts would not fit. Any suggestions. I am about ready to buy a used trans to get the car going. I have delt with this shop for twenty years and never a problem.
  2. #2 Re: Help 4t65e HD problems
    HUDSON
    I think the best suggestion would be to find find another repair shop that is willing to find the problem rather than just throw parts at it.
  3. #3 Re: Help 4t65e HD problems
    There isn't anything specific to 99 on the shafts. They are all the same 98-03 as are the diffs for the HD trans. 97 was the oddball year that used a different output shaft and clip to the diff.
  1. Tranny Swap 4T65E-HD to 4t65E
    By windowrattler in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2012, 03:47 PM
  2. 4t65e to 4t65e-hd swap
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-22-2011, 04:11 PM
  3. Can i use the 4t65e in my GTP?
    By SDGTP99 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2010, 02:35 PM
  4. 4t65E replacing 4t65e-hd question
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-29-2010, 10:33 PM
  5. "97" 4t65e-hd succesfully installed replacing the "00" 4t65e-hd
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-06-2009, 01:42 PM
