Thread: Vibrations Over 3k RPM
Results 1 to 13 of 13
  1. #1 Vibrations Over 3k RPM
    GT Level Member ShadowSwept's Avatar
    Kentucky
    I noticed on the highway recently that I get some pretty strong vibrations whenever RPMs go over 3000. Occasionally I'll get some hard shifts too, but it's rare. I checked the transmission fluid and there's no shavings but it's not red either- looks like motor oil with about 1k miles on it.
    2001 Bonneville SLE - L36, Cone Filter, 200k miles
    2003 Grand Prix GT
    - L36, Short Ram Intake, HV3, Emissions Delete, ZZP 3" Downpipe, Overkill Tune, 200k miles
  2. #2 Re: Vibrations Over 3k RPM
    maybe do a pan drop and filter change?
    how do the motor mounts look? They should be shot and cause the vibrations you feel at higher rpms.
  3. #3 Re: Vibrations Over 3k RPM
    Dec 2011
    Orlando, FL
    yeah check the motor and trans mounts. i've had the dreaded clunk and did the engine mount today. put a zzp poly in and its a great improvement. the factory piece was shredded @ 61k. i'm guessing the trans mount is in even worse shape so i'm ordering that piece too.
  4. #4 Re: Vibrations Over 3k RPM
    Kentucky
    I plan on changing the filter soon. As far as motor mounts, I can't really tell. I thought I had some really bad leaks, but upon further inspection it appears whoever maintained the car before I found it didn't know how to use a funnel and spilt every kind of fluid all over the place . So what would you say?
    2003 Grand Prix GT
  5. #5 Re: Vibrations Over 3k RPM
    that mount died long ago
  6. #6 Re: Vibrations Over 3k RPM
    Kentucky
    2003 Grand Prix GT
  7. #7 Re: Vibrations Over 3k RPM
    Kentucky
    So, Poly engine/trans mounts vs solid mounts; is the benefit worth the massive price difference?
    2003 Grand Prix GT
  8. #8 Re: Vibrations Over 3k RPM
    I'd go with solids, for you, you dont want poly mounts.
  9. #9 Re: Vibrations Over 3k RPM
    Kentucky
    'Kay...
    I'll be installing a shift kit with the new filter. Should I go with the one on the ZZP site or the Triple Edge?
    2003 Grand Prix GT
  10. #10 Re: Vibrations Over 3k RPM
    ZZP is junk.
    Trans go FTW
    You'll need 7-8 quarts of fluid when you swap the filter.
  11. #11 Re: Vibrations Over 3k RPM
    Kentucky
    Thanks for that, I almost bought it .
    Dexron 6, right? Anything else I should do in the process?
    2003 Grand Prix GT
  12. #12 Re: Vibrations Over 3k RPM
    If you can find dexron 3, run that, its what came in the trans from the factory and cheaper than dexron 6. But if not, dexron 6 is fine.
    Just make everything is clean when you go to install everything, wipe the magnet in the pan off and clean the metal trans pan gasket, because you will re-use it.
  13. #13 Re: Vibrations Over 3k RPM
    Minnesota
    Make your own solid mounts out of so called "solid" stock mounts.
  1. Vibrations...
    By Raviaan in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-08-2012, 10:51 AM
  2. Vibrations
    By randys100 in forum Brakes/Suspension/Chassis
    Last Post: 12-18-2011, 06:05 PM
  3. Highway vibrations...
    By Raviaan in forum Brakes/Suspension/Chassis
    Last Post: 10-12-2011, 07:36 PM
  4. Oil leak and vibrations
    By littlerobinson75 in forum General Tech Discussion
    Last Post: 08-20-2011, 06:25 PM
  5. More vibrations
    By Smokin2000gtp in forum General Tech Discussion
    Last Post: 12-19-2008, 08:28 PM
