Thread: Weird Transmission question
Results 1 to 6 of 6
  1. #1 Weird Transmission question
    SE Level Member ZachBW55's Avatar
    Ramsey MN
    Hey guys so I bought a warranty with 2000 Grand Prix GT when I bought it and it covers the transmission. Well the warranty has about 3000 miles left and the tranny is giving me some problems. My question is....is there anyway to make the tranny die quicker without a mechanic being able to tell? I was told that I could drain most of the fluid out and that would kill it but I thought automatic transmissions used pressure from the fluid? also how obvious would it be if I did that then just added fluid afterward?
  2. #2 Re: Weird Transmission question
    PA
    If it is giving you problems, that is enough to take it back under warranty. No need to kill it.
    2001 GSE
  3. #3 Re: Weird Transmission question
    Ramsey MN
    that what I thought but I guess its not bad enough yet
  4. #4 Re: Weird Transmission question
    SE Level Member Futures Passed's Avatar
    Dec 2011
    Florida
    If it is out of fluid, overheats, and has no leak point, it'll be pretty clear what happened. Just take it in as-is.
  5. #5 Re: Weird Transmission question
    Ramsey MN
    what if I drain the fluid then refill it after it dies?
  6. #6 Re: Weird Transmission question
    I'll help you kill it.
    Lets go joy riding.
    Burnouts around corners will chew it up.
  1. Transmission acting weird during startup
    By guitarguyucf in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-05-2011, 11:09 PM
  2. Weird electrical/transmission/stall issues
    By Perry125 in forum General Tech Discussion
    Last Post: 09-19-2010, 10:16 AM
  3. weird transmission problem?
    By stevenk8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-23-2010, 12:14 AM
  4. Transmission Problem? Weird shift patterns... Help!
    By Steve98GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-28-2009, 12:30 AM
  5. Weird sound, transmission??
    By thelost1123 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-15-2009, 04:23 AM
