Thread: Not Sure What...
Results 1 to 3 of 3
  1. #1 Not Sure What...
    Donating Users crock's Avatar
    Traverse City, Michigan
    This dosent happen very often. But when I come to a stop, lets say a light, and then go, no power. The motor will go up but the car wont move much... Then it sort of kicks, and then goes. Is the whole transmission going bad or is it just a sensor?
    Thanks
    99 GTP- 104s, 180 Tstat, 1.9 rockers, 3.4, ls1 MAF, KN, 3''DP, HF cat, GMPP Strut Bars, Crappy Tune, Broken Tensioner Mod.
  2. #2 Re: Not Sure What...
    Sep 2011
    MI
    Check your fluid level. If it is good it could be a pressure control solinoide, though it should throw a code.
  3. #3 Re: Not Sure What...
    USA
    Quote Originally Posted by crock View Post
    Thanks
    Maybe this problem... No Forward Cold Have also seen this happen when the fluid was hot.
