Thread: Trans locks out if Light is not on
Results 1 to 7 of 7
  1. #1 Trans locks out if Light is not on
    SE Level Member GaBear's Avatar
    Dec 2008
    Gainesville, Georgia, United States
    I have noticed the last couple of weeks that while I'm driving The Drive indcator Light will flash on and off and If the light is off when I turn the car off when I go to crank back up if the Light is still off I can not shift out of Park. I have had to use the SHifter Lock On the Side twice just to get it going. Does anyone know what causes this and How do I correct it.
    Thanks For All Info
    Bear
    97 GP GT 3.8
    BEAR
    97 Grand Prix GT: 2D/ 3.8 Liter/ AutoMatic / Cool Air Intake/ Full Magna Flow Exhaust
    More to come later
  2. #2 Re: Trans locks out if Light is not on
    Sounds like power or ground going into the console are shorting.
  3. #3 Re: Trans locks out if Light is not on
    Dec 2008
    The Drive indicator Light I'm talking about is on the dash, not the center console.
    BEAR
    More to come later
  4. #4 Re: Trans locks out if Light is not on
    Oh..then likely your PNP switch is going bad. It's on top of the trans.
    here's some info on it in this thread about how to add one externally..,. which your car has already.
    http://www.grandprixforums.net/how-a...ion-49297.html
  5. #5 Re: Trans locks out if Light is not on
    Dec 2008
    Thanks Bill Will Look into it and Get back with you.
    BEAR
    More to come later
  6. #6 Re: Trans locks out if Light is not on
    Dec 2008
    Bill can You tell me where to get the PNP Switch? My car has an External one on it already. I think its gone bad Now Light will not come on at all.
    BEAR
    More to come later
  7. #7 Re: Trans locks out if Light is not on
    Junkyard, me, another member?
  1. no crank, no power, key locks, shifter locks
    By flames1819 in forum PCM Tuning
    Last Post: 01-07-2012, 06:06 PM
  2. Door Locks
    By Jakescoots in forum Visual/Body Modifications
    Last Post: 05-03-2011, 06:38 PM
  3. Locks that have a mind of their own
    By redfiregtp in forum General Tech Discussion
    Last Post: 09-21-2010, 12:31 PM
  4. door locks
    Last Post: 09-21-2010, 11:42 AM
  5. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
