Thread: output shaft play?
Results 1 to 20 of 44
  1. #1 Re: output shaft play?
    Working on the side as a mechanic with a buddy who has a shop, I do see both sides of this and understand.
    Likely they are not driivng it enough to have the issue happen. In their time driving it..if the problem doesn't occur then it's tough for them to fix it. You meanwhile drive in many more conditions etc and notice the issue.
    Take a look at what happened with my car. I noticed it jumped about 1,000 rpm and slapped back into gear. Was positive at 173,000 miles that either seemed like a slipping trans or maybe a bad 4th clutch hub. Ran the car for a year (13,000 miles) that way and it didn't seem worse and with no consistency. Swapped the trans out for a fully rebuilt unit with upgrades, samw issues only more often. This problem turned out to be a bad coil pack. Never showed a misfire, nothing else. And since I was the only one working on the car, building the trans and diagnosing, I know that no one gave me the run around.
    Simply put.. be reasonable and they should return that favor. Too many people are too quick to yell and scream about problems because they think that fixes the problem. It doesn't, all it does is make the person you yell at, lose respect for you.
  2. #2 Re: output shaft play?
    Donating Users moddman's Avatar
    Midwest
    Nicely put........yelling doesnt solve anything....yet the shop owner yelled at me today saying he's not touching my car again.....
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  3. #3 Re: output shaft play?
    Midwest
    The GM bulletin describes exactly what is happening to my vehicle.....Here
    And I brought this paperwork to the shop owner who then showed it to the builder. The builder in his own writing wrote on the front page: Does not apply! I also gave them a part number and picture of the Borg Warner updated EPC and he wrote: Its already in there! So now with this evidence of his own writing of those two statements I believe I have a good solid case against the shop owner and the builder or just the shop owner since it was them whom I paid.
    The BBB told me to save all my paperwork reciepts (car rental etc.) and they are going to look at my vehicle with one of their shops to validate their claims of the updated EPC and if the bulletin really does not apply to my transmission even though it does say on it 2001-2007 Grand Prix. They said that it should not be that hard to prove it does since it says it in black & white on the GM bulletin. This is strictly the rebuilders fault which is entirely transferred to the shop that charged me for the transmission rebuild. Now it will be a matter of the shop owner if he wants to cooperate or wants to pay three times my money back. It works like this: The money I paid for the trans, the money I will pay for a "real" fully updated trans, and then the third amount is for my hassle that I went thru dealing with all this B.S. In essence if the updated 4T45E EPC is not in there it constitutes as fraud then if the bulletin does apply to my vehicle then it is conspiracy to avoid a warranty claim. As far as I know the BBB assigns an investigator while at a shop who takes pictures of the internals of the trans. and get the proof they need to move forward with the case. Let the truth be told so to speak. We shall find out soon enough.
    3.4" ZZP MPS Pull
  1. 4t65 Output Shaft Stuck
    By Admiral Jedi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-02-2012, 08:22 AM
  2. Gun Drilled Output shaft
    By MidnightBlue in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2011, 05:48 PM
  3. Output shaft questions?
    By johnsmith in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2010, 07:58 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Q? Output Shaft removal
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-22-2008, 09:07 AM
