Thread: Not going into gear at all
Results 1 to 14 of 14
  1. #1 Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
    So today on my way home from work I got stuck in rush hour and I was traveling about 15mph when I noticed that the car started revving at high rpm's and wasn't going anywhere. I pulled over and got a tow home thinking my tranny is gone. Now I'm thinking MAYBE it's the filter, but I would not be surprised the tranny is gone considering I heard it whining. Thought? Car won't go into ANY other gear at all.
  2. #2 Re: Not going into gear at all
    a whining trans is usually a bad trans pump.= not good news.
  3. #3 Re: Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
    So chances are my transmission is toast.
  4. #4 Re: Not going into gear at all
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    if you drop ya pan and see a goldish brown color.. gears are toast... what year is your car if you dont mind me asking
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  5. #5 Re: Not going into gear at all
    what year, miles, condition of the fluid? has the trans ever been serviced?
  6. #6 Re: Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
    1999 GTP, 173k, looked at the fluid on the side of the road and it looked pretty fresh, still clean and had the transmission color (red tint)
  7. #7 Re: Not going into gear at all
    Omaha, NE
  8. #8 Re: Not going into gear at all
    brunswick
    yea what he said^^^^^
  9. #9 Re: Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
    Okay well I went outside after letting it sit and it would go into gear, HOWEVER it is now making a very bad sound. Will be uploading a vid in a few min
  10. #10 Re: Not going into gear at all
    Omaha, NE
  11. #11 Re: Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
  12. #12 Re: Not going into gear at all
    sounds like its hurt, does it always sound so rattly? or is that the trans making all that noise?
  13. #13 Re: Not going into gear at all
    Dec 2011
    Grand Prairie, Tx
    That's the trans making all the noise. Just started this sound the first time I started it since I had it towed home. Didn't do this earlier when it stranded me on the highway
  14. #14 Re: Not going into gear at all
    Since, I've had noises in transmissions sitting still before, you are correct, it's not good. I've had whining when a filter got clogged, heck..even had loss of all gears.
    Looks like from those sounds, that you'll be doing a trans.
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. 02 GTP no 4th gear
    By dtun1 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-02-2011, 08:07 PM
  3. 01 GTP - No 1st Gear
    By DirtySteve in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-07-2010, 10:51 PM
  4. 4th gear gone, why?
    By Lowizle in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-02-2010, 05:55 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
