Thread: 06 trans slips at 70mph or above
Results 1 to 14 of 14
  1. #1 06 trans slips at 70mph or above
    SE Level Member walk76z's Avatar
    Surf City NC
    I have a 06 Grand Prix and the trans will slip at 70mph and above should i try to change fluid or what??
    Thanks Brian
  2. #2 Re: 06 trans slips at 70mph or above
    Omaha, NE
    Is the fluid low or miscolored?
  3. #3 Re: 06 trans slips at 70mph or above
    Surf City NC
    Looks fine not low
  4. #4 Re: 06 trans slips at 70mph or above
    Omaha, NE
    A fluid and filter change (don't flush) might be good for it, but I don't think it's going to solve your issue.
    It sounds like you may have a problem with line pressure or the torque converter maybe?
  5. #5 Re: 06 trans slips at 70mph or above
    Surf City NC
    I dont know why it only slips at 70mph and above
    Thinking it might be electrial?
  6. #6 Re: 06 trans slips at 70mph or above
    how do you know its slipping?
  7. #7 Re: 06 trans slips at 70mph or above
    Surf City NC
    the tack jumps up while the power goes down
  8. #8 Re: 06 trans slips at 70mph or above
    GT Level Member Jakescoots's Avatar
    Spring Lake, Mi
    Does removing the spare count as weight reduction?
    Badges on a car are just advertisements....Everyone already knows what it is. And if they dont, its a mystery. People like mysteries.
  9. #9 Re: 06 trans slips at 70mph or above
    Torque converter problems?
  10. #10 Re: 06 trans slips at 70mph or above
    Omaha, NE
    From the description it sounds like the converter isn't locking up.
  11. #11 Re: 06 trans slips at 70mph or above
    Surf City NC
    its like the first one
  12. #12 Re: 06 trans slips at 70mph or above
    Spring Lake, Mi
    Your converter isn't locking up all the time then
  13. #13 Re: 06 trans slips at 70mph or above
    Surf City NC
    is there any fixing or should i change the converter
  14. #14 Re: 06 trans slips at 70mph or above
    I'd ensure everything igniton wise is good first. Check tps and maf.
    All that will contribute to TCC lockup kicking in and out etc. High load, low rpm at 70 on our setup. Which means ignition is important.
  1. Noise from front end while going 60-70mph+
    By ajc549FF in forum Brakes/Suspension/Chassis
    Last Post: 03-23-2011, 10:02 PM
  2. Trans Slips Between shift when in normal
    By shawnschuldt in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2011, 09:25 AM
  3. trans slips only the first drive per day
    By shawnheck03gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-28-2010, 09:49 PM
  4. trans slips off the line when warm
    By beezer34ca in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-21-2010, 11:00 PM
  5. high rpms at 65-70mph
    By gpgtman83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-28-2009, 10:53 AM
