Thread: Transmission swap.
Results 1 to 12 of 12
Threaded View
  1. #1 Transmission swap.
    Out West
    Well, just did trans swap into the stock Regal.
    Picking it up, i check for leaks, leave it running for a little while to make sure before i set off on a 20 mile drive with it home.
    Well, everything looks okay and i set off with the wife behind me in the 04 GTP. Before the swap the car made the usual clatter from a bad coupler (Just haven't gotten around to replacing yet..)
    This clatter is still there as i'd have expected but seems more pronounced, Almost like a cracked flexplate would sound. Instant heebie jeebies...
    So we pull over and check on it in a lighted parking lot, It doesn't sound like it's coming underneath so much. We then get on the Turnpike and she's running smooth as a baby's bottom, Shifts are smooth, Slip is minimal to none, MPG's are excellent as i'd expect and the HPT doesn't indicate anything glaringly wrong with the car.
    Coming off the highway i kinda sense a very faint transmission fluid smell, Then when pulling off at the light the transmission refuses to really let the car go till about 3,000rpm, And it's only getting worse. I get it into my condo parking lot and proceed to back it in when it just refuses completely to move....Uh oh. Then i see smoke coming out underneath and out of the hood...
    Let her run for a little and try to back up again, and see more smoke, and hear a metallic squeak...NOT GOOD, so i shut her down and employ the help of some kind folks nearby backing it in to my carport. Notice a nice big and slick spot of trans fluid fluid while backing it in in neutral..
    I went over the HPT log after we got in and after the car started slipping, the engine started heating up at a much more rapid pace than previously as well as faster than the trans fluid itself. On the second log i noticed Cyl6 was misfiring quite badly...
    So my question is,
    What do you guys think went wrong?
    Whine with your Cheese?
  1. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  2. transmission swap
    By jrock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 01:04 AM
  3. Transmission swap question
    By jbro78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2010, 08:57 PM
  4. transmission swap questions
    By codyc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2009, 09:25 PM
  5. Transmission swap
    By ddyke2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2009, 10:19 PM
