Thread: Transmission swap.
Results 1 to 12 of 12
  1. #1 Transmission swap.
    Out West
    Well, just did trans swap into the stock Regal.
    Picking it up, i check for leaks, leave it running for a little while to make sure before i set off on a 20 mile drive with it home.
    Well, everything looks okay and i set off with the wife behind me in the 04 GTP. Before the swap the car made the usual clatter from a bad coupler (Just haven't gotten around to replacing yet..)
    This clatter is still there as i'd have expected but seems more pronounced, Almost like a cracked flexplate would sound. Instant heebie jeebies...
    So we pull over and check on it in a lighted parking lot, It doesn't sound like it's coming underneath so much. We then get on the Turnpike and she's running smooth as a baby's bottom, Shifts are smooth, Slip is minimal to none, MPG's are excellent as i'd expect and the HPT doesn't indicate anything glaringly wrong with the car.
    Coming off the highway i kinda sense a very faint transmission fluid smell, Then when pulling off at the light the transmission refuses to really let the car go till about 3,000rpm, And it's only getting worse. I get it into my condo parking lot and proceed to back it in when it just refuses completely to move....Uh oh. Then i see smoke coming out underneath and out of the hood...
    Let her run for a little and try to back up again, and see more smoke, and hear a metallic squeak...NOT GOOD, so i shut her down and employ the help of some kind folks nearby backing it in to my carport. Notice a nice big and slick spot of trans fluid fluid while backing it in in neutral..
    I went over the HPT log after we got in and after the car started slipping, the engine started heating up at a much more rapid pace than previously as well as faster than the trans fluid itself. On the second log i noticed Cyl6 was misfiring quite badly...
    So my question is,
    What do you guys think went wrong?
    Whine with your Cheese?
  2. #2 Re: Transmission swap.
    May 2011
    Kansas City
    looks like you need to burn the car nixon jk
    Reptile Tune (SOLD)
  3. #3 Re: Transmission swap.
    Quote Originally Posted by SerenityGTP View Post
    In all honesty dude FVCK you! my regal GS burned down in april! burning cars is not cool!
  4. #4 Re: Transmission swap.
    May 2011
    Kansas City
    on a more serious note...not enough duct tape
    ok so probaby need to go thru and change all the gaskets in the trans as well as fluid change
    Reptile Tune (SOLD)
  5. #5 Re: Transmission swap.
    Portland Oregon
    That sucks, where'd you get the trans? Sounds like you sprung a leak. Cyl 6 misfire could be a broken plug or mis-seated wire that got jostled in doing the trans swap. Find your leak an fill er back up and see what happens. Damage may already been done though.
  6. #6 Re: Transmission swap.
    Out West
    Cyl 6 was not misfiring on the way home. Only started after i shut her down and started it back up after the trans freaked out.
  7. #7 Re: Transmission swap.
    Determine where the fluid was coming out.
    Breather?
    Trans dipstick tube?
    Losing trans fluid and slipping makes an engine work more because it's not transmitting the power properly.
    Not to sound harsh, when you smell something and see something, turn the car off and find out what's up so you don't burn it down.
    Once you refill the trans after figuring out the leak, it'll likely be fine. You need to figure out the leak and misfire though.
  8. #8 Re: Transmission swap.
    Out West
    Home was only a couple blocks away so i limped it there.
  9. #9 Re: Transmission swap.
    Fires don't wait a couple blocks typically. I'm glad you made it and all was good overall, it's your car and your life you take the risk with.
  10. Likes snutmeez liked this post
  11. #10 Re: Transmission swap.
    Out West
    It wasn't smoking when i got off the highway. It only smoked once i got in position to back into my carport.
    It started off slipping mildly but got exponentially worse with every time i had to scrub speed off once i got off the highway
    I can post the HPT scans if you care to look?
    2shared - download Stockregal.zip
  12. #11 Re: Transmission swap.
    I'm more interested in where it leaked from. Scan isn't going to tell us what leaked, why it leaked or how it leaked. It's just going to show temps and slippage. None of that is really going to help me assist you.
  13. #12 Re: Transmission swap.
    Out West
    Unfortunately i can't really get under there to look really well atm.
  1. Transmission Swap
    By cmal37 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-30-2011, 08:42 PM
  2. transmission swap
    By jrock in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-13-2011, 01:04 AM
  3. Transmission swap question
    By jbro78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2010, 08:57 PM
  4. transmission swap questions
    By codyc in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-04-2009, 09:25 PM
  5. Transmission swap
    By ddyke2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-01-2009, 10:19 PM
