Thread: rpms bouncing while driving between 2nd and 3rd
Results 1 to 9 of 9
  1. #1 rpms bouncing while driving between 2nd and 3rd
    GT Level Member RyanL's Avatar
    Montreal, Quebec, Canada
    hey guys i dont know much about transmissions so this is why im asking. when driving normally when the transmission shifts from 2nd to 3rd the rpms will bounce up and down only between 1700 and 2100 rpms. no other speed will this happen. its like it shifts then isnt to sure it wants to go to 3rd and then cant decide until i get goin a little more. I do have a transmison oil cooler line (going to the oil cooler) that is leaking a little bit but check the fluid level often and still not low on oil. but will be replacing it probably next week. if you guys could give me your inputs it would be appreciated! thanks in advance
  2. #2 Re: rpms bouncing while driving between 2nd and 3rd
    SE Level Member GPmanter's Avatar
    Nov 2011
    Reynoldsburg, Oh
    Mine does the same thing & it bugs the crap outta me. I gotta figure out what is causing it.
  3. #3 Re: rpms bouncing while driving between 2nd and 3rd
    St. Cloud, MN
    I'm pretty sure your tranny gears aren't gripping right, which is probably from normal wear and tear.
  4. #4 Re: rpms bouncing while driving between 2nd and 3rd
    But under hard acceleration it has no problem gripping so would that be because of higher pressure in the lines cuz of higher rpm?
  5. #5 Re: rpms bouncing while driving between 2nd and 3rd
    Nov 2011
    Reynoldsburg, Oh
    More than likely it's a pressure control solenoid that has gone out. My 2008 was doing that & I took the car to the local dealer that used to sell Pontiacs & they checked the car out & told me when that sensor goes out the torque convertor clutch might have problems engaging due to the bad solenoid. Best bet is to take it to the dealer to have them check it & replace the part. Not sure of the cost though, as mine was still under the 5 yr/100k powertrain warranty.
  6. #6 Re: rpms bouncing while driving between 2nd and 3rd
    Grand Rapids, MI
    HA. ^^ if you knew the cost, you'd change your "best bet"
  7. #7 Re: rpms bouncing while driving between 2nd and 3rd
    Have a mechanic scan the car. This could be TPS, MAF, transmission or something else.
  8. #8 Re: rpms bouncing while driving between 2nd and 3rd
    Pennsylvania
    I'll put my chips down on vacuum leak. Check the rubber T off the LIM, which is a popular spot for dry rot.
  9. #9 Re: rpms bouncing while driving between 2nd and 3rd
    SE Level Member TheManInBlack's Avatar
    Dec 2011
    Detroit, Michcigan
    Had the same exact problem, took it to the dealer and told me the same thing gpmanter said. the part is about 70 but the labor was over $800 so im getting ready to fix now.. or try to..
  1. bouncing Rpms, then stalls."update with Fix"
    By thedudeSE in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-23-2011, 06:11 PM
  2. Exhaust is bouncing...HELP!!!
    By nikkigpgt00 in forum General Tech Discussion
    Last Post: 07-12-2010, 02:55 PM
  3. Bouncing projectors
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-19-2010, 08:34 PM
  4. Fixing Headlights' Bouncing
    By vega in forum Visual/Body Modifications
    Last Post: 02-20-2010, 07:31 PM
  5. 94 GTP gas smell and bouncing idle
    By rw53104 in forum 3.4L V6 (LQ1) DOHC
    Last Post: 02-17-2010, 02:21 PM
