Thread: No 4th gear. Fix or replace?
Results 1 to 12 of 12
  1. #1 Re: No 4th gear. Fix or replace?
    that's the one and no, the clutches don't come with it. Just the shaft is technically what GM calls the clutch hub shaft.
    You'll also need a set of channel plate gaskets.
  2. #2 Re: No 4th gear. Fix or replace?
    Dec 2010
    Minnesota
    Just to confirm the things I will need:
    - Hub shaft (~$40)
    - Clutches (from Triple Edge website - the 4th friction set AND the 4th steel plate set) (~$15)
    - Channel plate gasket set (also from Triple Edge website) (~$15)
    Anything else? I know there is the risk that once the transmission is opened, more things might be found that need replacing, but I hope this will get me by for a while. Thanks!
  3. #3 Re: No 4th gear. Fix or replace?
    Actually..you won't be able to see much else to replace. The 4th clutches will be nice to have. keep in mind there's a slightly thicker steel that goes in first and is called the apply plate. Replacing the 4th clutches is a choice,
    If you can..locate 2-4 long M6 x1.00 bolts. Say 60-80mm in length. Cut the heads off them and when you pull the channgel plate/VB as one unit, use them to hold the channel plate gaskets in place. Also..they'll help you guide the channel plate/vb assembly back into place. I put them in a couple threads only so that I can take them out by finger later.
    To pull the trans apart to do this.. I like to do this.
    Drain trans fluid
    Support motor from above.
    Unhook endlinks
    Pop both balljoints
    Remove 2 18mm bolts holding ps rack to subframe
    Unclip ps cooler line from subframe
    Remove any plastic clips holding wiring to subframe
    Undo two 15mm nuts on engine mount to subframe and 2 15mm nuts holding trans mount to subframe
    Lower subframe (4 x 18mm bolts)
    Pull driverside axle
    Remove as many trans side cover bolts as possible
    Now lower the motor/trans (tilting a little to the driverside if possible)
    Remove any remaining side cover bolts and lower assembly until you can wiggle the cover out.
    Gently unhook the wiring harness for the trans
    Unhook the valve slide that is connected to the shift cable (in this pic on the lower right, see the metal rod? That's what you need to unhook at the end we can't see that is under a soleniod.)
    Remove the pump from ontop of the VB (black screws only, leave that silver one in to hold the pump together)
    Pump off
    Remove bolts 230, 231, 377, 805, 433, 434, 435, 436, 374, 379, 380, 384
    This will get the VB/channel plate as one unit.
    Replace hub shaft, clutches (if applicable) and channel plate gaskets.
    When doing the gaskets. You'll notice there's one pin at the end of a long gasket. This is where the spare M6 bolts come in. Looking at the vb/channel plate combo, determine where you can put a bolt and still take it out once the assmebly is back in palce.
    Here's the 4th clutches, the part they engage in the middle is the hub shaft
    Removing the clutch plates, pull the shaft and note a plastic shim/bearing on the shaft. The nubs of that sit in the drive gear where this came out of.
    You will likely need to vigorously wiggle and turn the new shaft to engage it in place. Then put the clutches back in place (note orientation of the notches etc as the channel plate has to clear them) and it'll all go well.
    One thing you can check while you are there is the drive chains. You pull them with a finger toward the bottom of the case and the measurement to resuse changes IIRC needs to be 1/8" or more.
    More pics here Login to a private Photobucket.com album
    Password if needed is "Boosted"
  4. #4 Re: No 4th gear. Fix or replace?
    Dec 2010
    Minnesota
    Outstanding information. Thanks Bill!
  5. #5 Re: No 4th gear. Fix or replace?
    I even made a how to for the how to section. It's not every single step in detail, but it should get you through it if you have a couple wrenches and whatnot.
    PS.. balljoint nuts are 18mm and that ps line bolt at the subframe is a 10mm
  1. 2nd gear to 4th gear shift
    By 98grannyprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-17-2011, 01:03 AM
  2. How tuff is it to replace the 4th gear clutch hub?
    By JDCMoney in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2011, 11:37 PM
  3. Should I and what to replace??
    By torq455 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-28-2009, 08:13 PM
  4. How Do I Replace the FRP?
    By TZ250 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-27-2008, 11:07 PM
  5. Gear selector is a gear off after rebuild
    By skalor in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-17-2008, 11:08 PM
