I think it feeds the top. that way if you are low on fluid..it falls to the bottom and you don't run dry
I always thought it was the other way around. I thought they fed the bottom of the radiator and return out the top?
Can anyone confirm this? I'm not sitting at my car.
Edit: I searched and found my answer:
http://www.grandprixforums.net/trann...ler-32531.html
The fitting on the transmission that points straight down towards the ground is the feed fitting that sends fluid to the radiator transmission cooler, which should be going to the bottom fitting on the radiator.
The fitting on the transmission case that is parallel with the lower pan and points straight forward is the return fitting from the radiator and should be connected to the line going to the top fitting on the radiator.
Ya know..maybe it's like that to keep from having air issues because it's the highest point w/o a bleeder.
Coolant you always see the feed going to top of the radiator and return coming out the bottom.
