The transmission has to be removed from the car to swap an input shaft. There is an o-ring on the torque converter side of the input shaft that can only be removed and replaced with the torque converter off. If you do this in the car it will tear up the oring and you wont have lockup or have a lot of lockup and overheating problems.
