Thread: Sloppy Transmission Shifts, HELP!!
Results 1 to 20 of 27
Threaded View
  1. #1 Sloppy Transmission Shifts, HELP!!
    Grand Rapids, MI
    So of course with my luck: one problem after another. 03 Prix with 101k miles. Now what the hell? I was under the impression these trans were better, wtf.
    So anyway, the MAIN problem is a very very sloppy 1-2 shift. It has been doing it all day today. It takes a good 2 seconds to finally go into 2nd gear. It happens most frequently under light throttle. It will reach the top of 1st, hang up for a second or two, then finally go into 2nd. It's so annoying.
    Other than that, 2-3 will shift the same way on occasion, and tcc lockup feels kinda crappy at times, just jumpy, but not enough to notice or even call a problem at this point. I would say the main issue is simply very slow, sloppy shifts.
    Otherwise, today I went 3/4 throttle I'd say while I was on the highway and it did something strange when it kicked down in gear, I can't explain it. kinda like a slip or a jump, kinda slam-ish.
    I added Lucas...seemed to help it out some, but didn't cure it at all.
    So what could it be? Trans going out? Need fluid change? Or should i just push the whole car off a cliff and call it a day?
    The fluid looks decent I suppose, it's not dark or anything and it smells like trans fluid should smell lol. When the axles were changed I added 1.5 quarts afterwards to make up for the loss. And when I check it, its sort of hard to read, but judging by the holes in the stick, it's barely low if at all.
    Thanks!!
  1. transmission hard shifts when hot
    By ya61x in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2011, 01:46 PM
  2. transmission shifts better after rack and pinion swap
    By Scottydoggs in forum General Tech Discussion
    Last Post: 06-17-2011, 12:40 AM
  3. 1-2 sliping/sloppy shift...
    By Justin48 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2010, 01:47 PM
  4. Sloppy Mechanics Fall Dyno Day Oct 24th 2010
    By geforcextreme in forum Northeast
    Last Post: 10-19-2010, 07:54 PM
  5. Sloppy Mechanics Dyno Day Allentown Pa Sunday 10-25-09
    Last Post: 10-14-2009, 10:32 PM
