Thread: Need trans help
Results 1 to 6 of 6
  1. #1 Need trans help
    SE Level Member Max's Avatar
    Jul 2011
    IL
    Hey i need some help yesterday i was driving and out of no were something happen to my trans it seems like it is slipping really bad in every gear i pulled over and turned it off for about 10 minutes and then started it back up it was ok for about 30 seconds and then it happened again... im not sure what it is so any info on this will help....
    1997 Grand Prix 3800 SE
  2. #2 Re: Need trans help
    About the only thing we can probably guess from what you mention is that it's low on fluid.
    You don't mention if you checked the fluid level, if you haven't..do so before replying.
  3. #3 Re: Need trans help
    It's not looking good though 97's have the vacuum trans
  4. #4 Re: Need trans help
    Jul 2011
    IL
    The fluid level*was the first thing i checked, it was not low or anything
  5. #5 Re: Need trans help
    Change the fluid and filter and see if it helps at all. It kind of sounds like you have a plugged filter.
  6. #6 Re: Need trans help
    Jul 2011
    IL
    It went into the shop today so we will see what they say
  1. Gt gtp trans
    By jaygtp98 in forum General Tech Discussion
    Last Post: 03-12-2011, 12:39 PM
  2. Which car- wrx/trans am
    By Perry125 in forum Off Topic Discussion
    Last Post: 03-11-2011, 08:22 PM
  3. gtp vs 85 trans am
    By bballa0740 in forum Track Sessions and Kills
    Last Post: 07-15-2010, 12:50 AM
  4. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
  5. 06 trans in a 99 gt?
    By bronzemist99GT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-07-2008, 01:52 AM
