Thread: 1998 GTP transmission ticking noise
Results 1 to 6 of 6
  1. #1 Re: 1998 GTP transmission ticking noise
    Sep 2011
    California
    Thanks,
    I can certainly check the bolts but I'm
    unsure how to reach them. Do I need to remove the starter?
    I've replaced a clutch on a ford ranger but have never messed with a front wheel drive car.
    I'm not sure why the rattle would only happen when the engine is warm and the transmission out of drive. Is there a way to check it for cracking?
  2. #2 Re: 1998 GTP transmission ticking noise
    Underneath. there's a plastic cover held on with two 10mm bolts. Maybe a second around the starter that is held with another 10mm on the front fo the trans. Once off..you can see the flex and it's bolts. Well..kinda see.
  1. what is this ticking noise?!?!?
    By 2000gpgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2011, 07:36 AM
  2. l26 ticking noise...
    By Couch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-02-2011, 12:05 PM
  3. ticking noise
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-07-2011, 10:52 PM
  4. Lifter/ticking noise???
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 12:43 PM
  5. ticking noise???????
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 10-02-2008, 12:27 PM
