Thread: 2nd gear to 4th gear shift
Results 1 to 8 of 8
  1. #1 2nd gear to 4th gear shift
    Jul 2011
    Penticton, bc
    98 grand prix . 3.8, no mods 212,000kms
    when accelerating in town 0-50kms an hour it shifts fine from first to second, but when it should shift to 3, it shifts directly into 4th gear. . so when i step on the gas a little harder to accelerate after the failed 2nd 3rd shift, the car seems to bog a little , and i really have to stomp on the gas to get it to down shift. when it down shifts it goes right to 2nd, sometimes 3rd catches.
    On the highway at 100kms an hour, same thing to get out to pass someone i have to really stomp on it to get it to shift down, and when it does it shfits very hard.
    Anybody else had these problems ? Would a full trans flush be better than just a filter change? any recomended additives?
  2. #2 Re: 2nd gear to 4th gear shift
    Destroys cars izup69's Avatar
    Iowa
    Check the fluid level and see/smell if it is burnt. Drop the pan and check for hunks/shavings of metal. Sounds to me like your 3rd gear is toast but I know little about these transmissions. Is it throwing any codes ?
    06 base open cone,2.5 inch dp into high-flow cat,window tint,drilled rotors.
    97 GTP ubend delete,drilled and slotted rotors,de-badged,open cone,6k HID,All aftermarket speakers
  3. #3 Re: 2nd gear to 4th gear shift
    Jun 2011
    Detroit, MI
    DO NOT FLUSH IT, it will ruin your tranny at that mileage. Do a pan drop with filter change.
    iLoveSpade
  4. #4 Re: 2nd gear to 4th gear shift
    3rd gear is a commonly used gear in most of our daily driving. It's common for the clutches to wear or the third gear sprag to go bad. When the sprag goes bad the gear can not engage at all.
  5. #5 Re: 2nd gear to 4th gear shift
    SE Level Member bstuby's Avatar
    charleston, IL
    I'm still having the exact same problem. Been going on for about 6 months now. Its kinda like driving a car with a 2600-2800 stall in it. It just basically slips all the way up to 2600 rpm and finally catches. Kinda annoying at first, but I got used to it. Just waiting on it to go completely out so I can replace the damn thing.
    98 GTP/ SD Headers, 180 T Stat, AL 104's, CAI, Intense pcm, 3.4 thrasher mps
    98 TA, Pacesetter coated LT/ ORY/ LS6 Intake/ SLP Lid/ Magnaflow CB/ Tuned
  6. #6 Re: 2nd gear to 4th gear shift
    GT Level Member torq455's Avatar
    Dec 2008
    Alabama
    Don't wait. It may cause more damage and make the rebuild more expensive.
    2002 GTP: K&N, 3.2 pulley, flipped mounts. ZZP SS headers, 180 stat, NGK TR6's, MSD wires, Reptile ported TB, ported S/C, ported LIM, Intense Stage II heads with larger Manley severe duty SS valves, Yella Terra 1.9 full roller rockers, LS6 springs, Racetronix fuel pump re-wire, Oil pressure "kit", JMB FWI. Mustang dynoed at 240 WHP, 272 WTQ.
  7. #7 Re: 2nd gear to 4th gear shift
    charleston, IL
    I'm not going to rebuild it. Getting one out of the junkyard. Car has to many miles on it to spend 1500-2000 to rebuild it. Thats more than half of whats its worth
  8. #8 Re: 2nd gear to 4th gear shift
    Jul 2011
    Penticton, bc
    Im glad im not the only one out there expeirencing this.. I changed the fluid and filter last week and it kinda helped a bit, however there were alot of metal shavings on the magnet inside, and some metal chunks in the pan . The car has 200,000kms on it, and the fluid sure told a story. looks like im on a hunt for a trans here too.
    Looks like my ford is getting put back on the road
  1. Gear shift lever hard to operate
    By jokyfo in forum General Tech Discussion
    Last Post: 10-11-2010, 04:48 PM
  2. Tranny takes a while to shift into 2nd gear
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-19-2010, 01:57 AM
  3. Gear Shift Appearance
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 03-03-2010, 11:59 PM
  4. Wont shift into 4th gear
    By youngmcse in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-08-2009, 05:23 AM
  5. hard shift into 3rd gear
    By gtpforever15 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-08-2008, 02:02 AM
