Thread: need help with axle boot!!!!
Results 1 to 5 of 5
  1. #1 need help with axle boot!!!!
    racine,wis
    just wondering what is the best way to fix a inner axle boot that came off? the boot is is fine the band just slipped off. can i use a big hose clamp? or do i have to stick with the band clamp. thanks!!
  2. #2 Re: need help with axle boot!!!!
    You need to repack it with fresh grease (likely all yours goo'd all over the area) and then reclamp it with a cv clamp. A hose clamp will off set the weight and likely cause a vibration.
  3. #3 Re: need help with axle boot!!!!
    racine,wis
    yea there is grease everywhere kinda figured a hose clamp would do that. is there a better clamp out there or are they pretty much all the same.
  4. #4 Re: need help with axle boot!!!!
    There's two types. One is a crimp style and the other is a pull and fold over style.
    Personally though. I go down, spend $60 for a new axle and put it in. It's not worth the $10 or so savings after buying the tool and parts to fix an axle boot.
  5. #5 Re: need help with axle boot!!!!
    Charles City, IA
    QTF
    SMGPFC Two Nipple General
  1. Inner tie rod boot
    By bonerjamz03 in forum Brakes/Suspension/Chassis
    Last Post: 10-16-2010, 08:40 PM
  2. boot cleaning
    By Warbeaver in forum General Tech Discussion
    Last Post: 05-12-2010, 02:58 PM
  3. Boot this nikencshoes guy!!
    By Nickell in forum Forum Bugs/Suggestions
    Last Post: 12-02-2009, 05:07 PM
  4. So..who uses boot protectors?
    By 99prixgt in forum General Tech Discussion
    Last Post: 04-08-2009, 07:39 PM
  5. Did my CV boot blowup?
    By GeddyLee in forum Brakes/Suspension/Chassis
    Last Post: 05-02-2008, 11:12 AM
