Thread: Transmission almost dead????
Results 1 to 9 of 9
  1. #1 Transmission almost dead????
    ontario
    ok well at this point im assuming my transmission is toast.
    at idle i am get a rotation clunking noise from around the inspection plate, the gear shifts are lagging or missing and harsh shifts.
    the following codes are listed
    P0717
    P0716
    P0730
    P1811
    has anyone seen this before?? i just want an idea of what im in for
    dave if you read this, any ideas?
    as well i have obtained a 4t65e out of a 01 monte carlo and how would i tell if it is the same gear ratio of the one that i have
    thanks
    Mike
  2. #2 Re: Transmission almost dead????
    P0717 Input speed sensor no signal
    P0716 Input speed sensor signal open/intermittent
    P0730 Incorrect gear ratio
    P1811 Max adapt shift
    Ok, first thing is always google and at least list out the names of the codes you are providing, some folks will skip past your post if you don't try to help us help you. I'm in a good mood and hooked ya up.
    Max adapt shift is the trans trying to limp you along and commanding max pressure. Usually a by product of another issue.
    Incorrect gear ratio, based on the lack of the pcm seeing the input speed. It's likely saying about the gear ratio.
    Input speed sensor issues, hmm yes this is an issue. I would say either your ISS reluctor wheel has some off the gear (you mention noises) or there's an issue with the sensor and or wiring. A sensor/wiring won't cause noises though.
    So.. I'll link you to pics of what happens.
    http://www.grandprixforums.net/my-re...ion-51157.html
  3. #3 Re: Transmission almost dead????
    Feb 2009
    flintnasty MI
    Willing to bet that you may just have a input shaft speed sensor issue, as a missing input shaft wheel would not cause a "open circut" code.
  4. #4 Re: Transmission almost dead????
    Quote Originally Posted by 02bluegtss View Post
    I agree Scott, this part had me sayimg "that is familiar"
  5. #5 Re: Transmission almost dead????
    Feb 2009
    flintnasty MI
    PTSD
    Post tramatic input shaft stress disorder.
  6. #6 Re: Transmission almost dead????
    SE Level Member Wisconsingrandprix's Avatar
    Aug 2011
    roun here
    yes mine just went same thing and i dropped the pan and cause of all the hard shifting there were hard parts up the wazoo in there
  7. #7 Re: Transmission almost dead????
    Aug 2011
    roun here
    or the parts might be cause i top swap with a non hd trans
  8. #8 Re: Transmission almost dead????
    Transmission Expert Trannyman95's Avatar
    Fort Wayne, IN
    Since you have a noise to go with the codes- which are related other than P1811 may have already been there, I would bet your input speed sensor alignment pins got hammered off and it is freely rolling around in there. With no ISS signal it will throw an incorrect gear ratio code since the input rpm is not doing much if anything at all. A quick scan will will show transmission iss rpm and prove what it is or is not doing.
  9. #9 Re: Transmission almost dead????
    ontario
    Hey
    Billboost thanks for the link and all the info I appreciate it, I'm a licensed automotive technician and at the end of the day I get lazy on anything to do with my own car. Lol
    The noise happens almost all the time and it is a clunking like noise. Sort of like a spun rod bearing but I've narrowed it with my stethoscope to behind the transmission inspection Plate.
    I have hooked up the scan tool to look at the iss rpm and at idle it will be reading zero and if I rev the engine it will all of sudden start reading with values jumping from 400 to 800 and while driving it's all over the place as well
    I do have another transmission ready to go in but I was wondering if anyone has seen this before. I'm always looking to Learn more about our cars.
    Mike
  1. Is it dead?
    By klj5022 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2011, 10:49 AM
  2. I think my GTP is dead. :-(
    By nickbuol in forum Off Topic Discussion
    Last Post: 11-25-2010, 01:13 AM
  3. Hello I am the Dead-Man
    By iamthedeadman in forum Introductions/Noob Questions
    Last Post: 04-06-2009, 12:31 PM
  4. car = dead
    Last Post: 02-10-2009, 09:03 PM
  5. Dead!
    By GTPluv in forum Southwest
    Last Post: 02-26-2008, 01:04 AM
