Thread: Replacing CV shaft and trans fluid pouring out
Results 1 to 13 of 13
  1. #1 Replacing CV shaft and trans fluid pouring out
    Aug 2011
    KS
    I replaced my driver's side CV shaft this morning with no issues (just a small amount of fluid leaked out) and then I went to do the passenger side and when I pulled the shaft out it POURED trans fluid everywhere. There was no leak prior to me pulling out the shaft. Is this simply the axle shaft seal or is there something else in the trans that could be the problem. FWIW that axle has probably been bad for a year with some vibrations the entire period. Oh and it's an '01 SE.
  2. #2 Re: Replacing CV shaft and trans fluid pouring out
    Aug 2011
    KS
    I know I'm new to the site but 43 views and no ideas? I'm thinking I'll just put the new shaft in and see what happens.
  3. #3 Re: Replacing CV shaft and trans fluid pouring out
    Charles City, IA
    You had it jacked up goofy thus the fluid level was over the opening does it leak with the new shaft in? Fluids tend to drop out of gaping holes.
    SMGPFC Two Nipple General
  4. #4 Re: Replacing CV shaft and trans fluid pouring out
    like how much we talking here.
    id say maybe half a quart came out my pass side when I did mine.
  5. #5 Re: Replacing CV shaft and trans fluid pouring out
    SWPA
    The trans fluid is held in by the axle and the seal. When you removed the axle you opened a gaping hole to the trans fluid.
    EDIT: Simultaneous posting for the win.
  6. #6 Re: Replacing CV shaft and trans fluid pouring out
    Aug 2011
    KS
    Tough crowd in here. I brought it up because everything I've seen before says only a small amount will come out. I thought it was jacked up evenly in the front but I guess not. I need to find a spring compressor now because I can't get the damn strut back in.
  7. #7 Re: Replacing CV shaft and trans fluid pouring out
    Charles City, IA
    Do you have the sway bar link off the control arm? That will help a lot.
  8. #8 Re: Replacing CV shaft and trans fluid pouring out
    Buffalo
    Funny. I didn't spill a drop? Normal?
  9. #9 Re: Replacing CV shaft and trans fluid pouring out
    Charles City, IA
    All depends on how the car is jack up or if that side was lower than the other at one time causing fluid to pool.
  10. #10 Re: Replacing CV shaft and trans fluid pouring out
    GT Level Member SliceTheRice's Avatar
    South Jordan, UT
    Quote Originally Posted by ggsz28 View Post
    Yeah, same thing happened to me when I replaced the passenger side - a lot more trans fluid dumped out everywhere and I thought it would only be a little. In the future, if I have to replace an axle shaft, I'm going to try to elevate the side being repaired and see if that helps.
    2000 Pontiac Grand Prix GTP
    (3.4 MPS, DHP 1.0 tune, ZZP Plog & 3" DP, 2.5" cat-back exhaust, resonator delete, AL104 plugs, 180* T-stat, Falken Ziex 245/45/18 tires)
  11. #11 Re: Replacing CV shaft and trans fluid pouring out
    GTX Level Member GTPSHAWTY's Avatar
    brunswick
    when i did mine..it drained a lil bit... but when the jack fell..... fluid poured
    CTRACER: YOU SHUT YOUR MOUTH WHEN YOUR TALKING TO ME
  12. #12 Re: Replacing CV shaft and trans fluid pouring out
    Normal in my book
  13. #13 Re: Replacing CV shaft and trans fluid pouring out
    Aug 2011
    KS
    Got it back together today. Loosening up the sway bar end link allowed me to drop the control arm enough to get the strut back in. Still has a small vibration but much better than before. I think it needs new LCA bushings since they're popping...I wonder if that can lead to any vibration.
  1. Replacing All of Your Transmission Fluid
    By stuzman in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-26-2011, 08:52 PM
  2. There's trans fluid everywhere!!
    By FuglyGTP in forum General Tech Discussion
    Last Post: 09-05-2009, 05:08 PM
  3. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  4. Loose Trans axle output shaft (wobble)
    By PCweber in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-21-2009, 10:22 PM
  5. Replacing Tranny and S/C fluid.
    By Freebeer187 in forum General Tech Discussion
    Last Post: 08-20-2008, 07:31 AM
